Old 09-08-2006, 10:42 PM   #1
supfoo514
supfoo514 is on a distinguished road
Default throttle cable
Hi, I was just wondering if anyone knew of any parts stores such as kragens or autozone that would sell a throttle cable for my 91 turbo around the san francisco bay area. Also wondering how much it would cost. Thanks.
91 Turbo Automatic MKIII
a.k.a "Sammie"
supfoo514 is offline   Reply With Quote
Old 09-16-2006, 02:53 PM   #2
Burn N' Up
Burn N' Up's Avatar
better off calling these guys 18007657100 TAP Toyota Auto Parts recycling they are in Sacramento and are cheaper than dealership if you don't mind used parts. I've yet to have a problem.
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
Throttle Cable # ethan12510 MKIII Supra 7 05-15-2007 05:44 AM
where can i get a throttle cable for 1jz swap 86_sports_1jz MKIII Supra 1 03-15-2007 09:50 AM
Extra Cable? 808Supra MKIII Supra 1 08-17-2006 08:15 AM
I need help on the computer and your info on the throttle cable! 89n/aA/T-2turbo5spd MKIII Supra 2 05-07-2006 05:25 AM
