ive been leaking oil on my 87 supra so i replaced the pan gasket and just noticed the other day the oil is leaking around the valve covers i was wondering if it could be a headgasket starting to go or if i could just tighten the head down.( really dont want to put new gasket in plan on doing the 7mgte swap this winter) Please help plus lately its been hard to shift into any gear reverse is the worst bad tranny??
Please Help my Cindy is sick |
i aint 100% sure about where your oil is coming from by what you say but if its the cam covers on the top of the engine held down with the cross screws then its quite normal for these to shake loose and a re tighten soon solves the problem,
Good luck |
yea thats were its leaking from. u just think they need tobe tighten down? thanks. i also fixed the shifting problem leaking clutch slave cylinder. thanks again
yeah its a common problem for them to come loose, tightening them back down should work but if they are really loose then maybe a quick replacement of the screws would work
valve cover gaskets are leaking | D_Train | MKIII Supra | 18 | 03-19-2015 04:53 PM |
Leaking Oil | 94TT | MKIV Supra | 7 | 10-29-2014 12:41 PM |
Oil Pan Leaking! | teedoff00 | MKIII Supra | 3 | 09-01-2007 11:54 AM |
Oil Is Leaking I Have Pics!! Need Help!! | Ahmad88 | Non-Generation Specific Questions | 18 | 07-09-2006 03:56 PM |
water leaking from A/C inside car | Ron90Turbo | MKIII Supra | 2 | 09-12-2005 04:31 AM |
