#1 |
I would stay away from a lightweight under drive pulley unless your crank has been balanced for it. Without a dampener on it you will destroy your bearings and fry your engine.
I would say to hop up a NA, engine wise, first exhaust and intake. I would favor a 2.5" ID cat back, test pipe or high flow cat, and some custom headers. You can buy headers but I have yet to see one that is tuned for the firing order in a Supra. As for intake, you can get a dry filter, and do a little fabbing with some tubing to clean up the flow path to the intake. If you plan to dig into the engine, you can do a port and polish and put some more aggressive cams in, get your rotating assembly balanced and blueprinted. Then no matter what you do, even if its nothing you can get a MAFT Pro, it will allow you to tune your engine, so you can do almost anything and then tune the MAFT Pro to run your engine correctly. Other than engine upgrades, I would suggest the common, light weight fly wheel, upgraded clutch, one piece drive shaft, and the changing of all the fluids in everything. Hope this helps, good luck. |
#2 |
Damn I may as well retire. Chambers is everywhere I'm trying to be.
#3 |
lol, I have learned from the best my friend.
#4 |
Hey Shiftysupra you dont have to relocate the ECU man do some research there is a lot of people like me that just did the tuck method and the ECU is in the stock location without extending the harness. Now that I got that out of the way 2500 plus install sounds kind of cheap considering all of the changes that have to be made and the fact that it is better to get a clip. Not so much for the 90 supra but just a good idea then you get all of the other stuff that the motor tranny ecu and harness do give you like the stock intercooler, piping, and so on. I would say if you have a NA and want to work it over it is cheaper to upgrade to a 7MGTE than go the 1JZ route unless you just have a want for the 1JZ. Don't think I am talking you out of it because I love mine but just have to be ready for all of the headache in putting it in and if you arent a really good mechanic then you would be best off not going that way at all. Also the 1JZ is a lot more reliable IMO than the 7M just because of the work you got to put into it to make it faster. If you dont believe me then ask Arron at driftmotion he will tell you the same thing they love the 1JZ over the 7M.
1987 supra NA 5 speed 1JZGTE swap Tokico Illumina 2 and Eibach springs Tokico pillow blocks Suspension Techniques front and rear sway bar HKS super dragger cat-back exhaust plus test pipe Greddy Profec B spec 2 boost controller HKS type 1 turbo timer Supra sport solid steel drive shaft Walboro 255 fuel pump JZA70 Front end mod 18" Volk Racing AV3 18x8.5 front 18x9.5 rear Last edited by supradaddy0803; 07-03-2008 at 01:56 PM. Reason: last minute thought |
#5 |
my apologies... I have come a long way instead of the "post because you can" days....
Helpful Supra Websites | mrnickleye | MKIII FAQ | 11 | 03-13-2012 08:31 PM |
1990 Supra Turbo -Any Good!!? | ukferrari | MKIII Supra | 3 | 12-13-2009 09:13 PM |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
In Need of New Engine 4 1990 Supra | SuperSpartan | MKIII Supra | 4 | 05-26-2008 02:54 PM |
1990 supra turbo engine issues help | jespat | Non-Generation Specific Questions | 4 | 01-24-2008 02:37 AM |
