Old 09-11-2006, 02:04 AM   #1
tone loc
tone loc's Avatar
Default loc's automatic to manual conversion!!!!
Im about to start the process but i kinda want to do some more research on top of my other research. I have a couple more questions. could i bolt up the r-154(turbo) trans to the n/a engine? would i have to splice wires and shit or will the automatic wires work for the manual? if someone could explain how to put in the clucth in some easy to understand instructions? How do i take off the drive shaft? Thanks for the help and i will being taking detailed pics and notes and all that good stuff.
Old 09-11-2006, 07:12 AM   #2
Murd
You'll need quite a bit to do this. Not just the R154. You'll need the pedals, both brake and clutch, as the brake on the auto is too big. Clutch master cylinder, all the lines and cables, I don't know all of it, but there's a list somewhere. Also the tach won't work without some soldering work.
http://4cefed.com/tech/natachchanges.jpg
Here's a link of the tach changes that need to be done. Where I got it from was from this link
http://4cefed.com/conversion.html
He used to have auto to manual, but the link doesn't work anymore.
Old 09-11-2006, 01:27 PM   #3
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
u will also need a new drive shaft the ones for the auto r different size fom the manueal
Jeff_5_7 is offline   Reply With Quote
Old 09-11-2006, 04:42 PM   #4
tone loc
tone loc's Avatar
what exactly is a tach? Can i get from a manual supra?
Old 09-11-2006, 08:57 PM   #5
Murd
tachometer, tells you engine RPM, should have one to the left of your speedometer.
Old 09-12-2006, 03:40 AM   #6
tone loc
tone loc's Avatar
ohh ok. can i take one from a manual supra?
Old 09-12-2006, 03:47 AM   #7
Murd
You should be able to get the PCB from the manual supra, the board I linked with all the resistors.
Old 09-13-2006, 04:13 PM   #8
Isphius
Isphius's Avatar
youll also need the r154 bellhousing, driveshaft, i think starter motor but im not sure, maybe not, clutch master/slave cylinders, a hydraulic line for the clutch, and a clutch kit with pressure plate. Then im still not sure cause i havent started the conversion yet.
Old 09-13-2006, 04:20 PM   #9
AzzKickin101
AzzKickin101 is on a distinguished road
Default I was woundering if it was possible
I've been woundering if it was possible to do the conversion...
How much $ do you think it will coust to make the swap?
AzzKickin101 is offline   Reply With Quote
Old 09-13-2006, 04:45 PM   #10
Isphius
Isphius's Avatar
It depends on if yu get new or used parts, and whatnot, I figured 1200 ish for mine, with used trans and other parts, and a brand new flywheel, clutch kit and aluminum driveshaft
Automatic to Manual Conversion sprite059 MKIII FAQ 30 09-02-2010 12:47 AM
Automatic To Manual InColdBlood MKIV Supra 6 03-19-2007 07:52 PM
automatic to manual conversion aznwaterboy MKIII Supra 1 10-04-2006 02:29 AM
