-   -   Wanna install electric fan.... (http://www.toyota-supra.info/forums/mkiii-supra/6043-wanna-install-electric-fan.html)
Supra89 09-12-2006 07:48 PM
I want to replace the stock fan with an electrical fan. I was wondering if I could pull the stock fan and clutch out and just wire an electrical fan in. My question is concerning the two smaller fans just to the side of the main one. Is there any way I could wire my new electrical fan into those smaller fans. Basically, are those fans made to turn on when the block gets too warm, so that the main fan would do the same? That way I wouldnt have to pull the whole fan shroud out of the car, because I dont know how important those two smaller fans are.
mrnickleye 09-13-2006 05:54 AM
Those 2 fans come on when the a/c high side pressure reaches a certain level. Usually on in slower driving, but can go off when out on the hwy, as enough air flowing will lower the pressure.
Read "need some advice" in the general section.
Also try the 'search' function for related threads on electric fans. I know I've explained my setup several times.
ddmcse 09-13-2006 10:38 AM
my electric fan is tapped into the wires for the small fans
the fan comes on when the engine reaches a certain temp then stays on
mrnickleye 09-14-2006 06:48 AM
^^^ the N/A cars are set up differently. The little fans only come on with the a/c. Except mine, cause I wired a grounding switch inside at the coin holder so I can turn them on whenever I want.
The turbo cars have a temp switch at the thermstat housing that actuates the fans too.
http://www.cygnusx1.net/supra/library/TSRM/d/D_30.html
Reeves 09-14-2006 10:26 AM
Ever since I got my engine rebuilt, those fans kick in and they are loud as hell. They are really annoying. I was hoping an electric fan would replace them but I guess not.
mrnickleye 09-15-2006 01:27 AM
Perhaps (not maybe) the temp switch is bad, and allowing the fans to come on too early. When the A/C is off, They are only needed at slow speeds around town, and prolonged idle.
Reeves 09-15-2006 06:53 AM
Where is the temp switch located, and how do I go about checking if it is fouled up?
nelly26 10-07-2006 01:59 AM
the two fans come on when you use a/c but the engine gets to hot it will kick in to aid main fan its ok part of cars programme the engines on the supra are very hot runners
