Old 03-30-2005, 07:46 PM   #1
87supraguy
87supraguy is on a distinguished road
ive been leaking oil on my 87 supra so i replaced the pan gasket and just noticed the other day the oil is leaking around the valve covers i was wondering if it could be a headgasket starting to go or if i could just tighten the head down.( really dont want to put new gasket in plan on doing the 7mgte swap this winter) Please help plus lately its been hard to shift into any gear reverse is the worst bad tranny??
Please Help my Cindy is sick
87supraguy is offline   Reply With Quote
Old 03-30-2005, 10:28 PM   #2
das
das is on a distinguished road
i aint 100% sure about where your oil is coming from by what you say but if its the cam covers on the top of the engine held down with the cross screws then its quite normal for these to shake loose and a re tighten soon solves the problem,
Good luck
das is offline   Reply With Quote
Old 03-31-2005, 01:05 AM   #3
87supraguy
yea thats were its leaking from. u just think they need tobe tighten down? thanks. i also fixed the shifting problem leaking clutch slave cylinder. thanks again
Old 03-31-2005, 11:15 AM   #4
das
yeah its a common problem for them to come loose, tightening them back down should work but if they are really loose then maybe a quick replacement of the screws would work
valve cover gaskets are leaking D_Train MKIII Supra 18 03-19-2015 04:53 PM
Leaking Oil 94TT MKIV Supra 7 10-29-2014 12:41 PM
Oil Pan Leaking! teedoff00 MKIII Supra 3 09-01-2007 11:54 AM
Oil Is Leaking I Have Pics!! Need Help!! Ahmad88 Non-Generation Specific Questions 18 07-09-2006 03:56 PM
water leaking from A/C inside car Ron90Turbo MKIII Supra 2 09-12-2005 04:31 AM
