Old 09-24-2007, 09:27 PM   #11
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Yeah looks like the gauge was damaged. As far as your speedometer I checked mine just now and yes it should be at the 0mph mark...but mine is a little bit above 0mph...reading 2mph about. That's with the car off. I'm not sure if it was messed up because of putting the cluster back in. There's one round slot that you have to fit it into and it's green colored. I believe that's for the odometer though...so if that's the case the gauge itself might be having some electrical problem. Did you by any chance unscrew a ground wire on the back of the cluster? Or did you by any chance physically touch the speedometer needle or flip the cluster upside down or all around? Doing so might damage its calibration. As far as your blinkers...the only time I experienced that problem was when I replaced the signal/light controller from the original 86.5 to a newer 89+ supra one. After I did that my signals wouldn't come on at all...so what I did first was check to see if the hazard switch would light them up. It did and after I checked that the signals worked again...very unusual.
Drag0na5h is offline   Reply With Quote
Old 09-24-2007, 10:54 PM   #12
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
wow i with my luck i probably messed the whole thing up im gonna look at it it a few mins and tell ya what i find out with the cluster i guess thats what i get for trying to fix it lol, and also does anyone know were to get a denso replacement oem gauge for the 87 na could you get osmething like that at autozone or something
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
Old 09-25-2007, 12:41 AM   #13
Drag0na5h
Drag0na5h's Avatar
In my case I live in a big dismantler city. It's quite easy to find a used Supra and get the gauges out of it. If it's hard to find one I could help you out.
Old 09-25-2007, 05:43 PM   #14
carfanatic89
alright i fixed the speedo i just took the needle off and moved it over to the 0 spot (pretty simple) but i still cant figure the turnsignals out my hazards still work but the turns dont not in or out of the car. An no blown fuses I dont know what i can do i guess just a process of elimination
Old 09-25-2007, 05:47 PM   #15
Drag0na5h
Drag0na5h's Avatar
Hmmm well they stopped working after you took out the gauge cluster right? It's it possible you miss putting in a plug or didn't plug it in all the way?
Old 09-26-2007, 05:56 AM   #16
carfanatic89
i dont think i did but i could have ill work on it more 2morrow mabye ill have better luck
Old 09-27-2007, 02:36 AM   #17
carfanatic89
now that i think of it i had trouble with the column switch when i first bought the car. I had to dismantel it and put it back together and it took about a week for it to say on like its suppost to. I would have to click in into the turn position then put pressure on it to get it to turn on Ill test it and see what i come up with
Old 09-27-2007, 08:55 AM   #18
Drag0na5h
Drag0na5h's Avatar
Yeah when I changed out the old 86.5 column control switch to a newer 89+ switch I had to modify the contact wires for the cruise control. There was one extra wire on the harness of the new one that I had to eliminate. Doing so required me to take apart the column control switch and I can see how if something isn't aligned or press fitted properly it won't work. It's possible maybe a snap fit flange broke off and that's why you have to press down on it with pressure to get it to work.
Old 09-27-2007, 07:28 PM   #19
carfanatic89
im just straight up getting pissed now. I have checked EVERTHING on this car. This is a list of all the things i have checked. Turn switch, fuse, voltage to the fuse, the guage cluster, all the bulbs and sockets, relay, voltage to the turn switch and every thing is fine what the hell is the problem the onlything i can think of is the wires to the lights but y would it just all the sudden stop working after the guage is removed and put back in, and for that matter the hazards work so it couldnt be the wires to the bulbs. Would that little box under the left brake light assembly in the rear. I know it has something to do with the turn signals.
Old 09-27-2007, 08:11 PM   #20
carfanatic89
I was a ground, im happy now lol
oil pressure sensor sundevil1 MKIII Supra 2 12-06-2008 08:21 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Whats The Thread on The Oil Pressure Sensor? Chambers MKIII Supra 2 01-22-2008 02:24 PM
pressure sensor? west_side_supra MKIII Supra 3 10-25-2007 05:23 PM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
