Old 09-19-2006, 03:32 PM   #1
redmaro
Default Turbo gauge question
Is turbo gauge suppose to be at zero when in idle?
Old 09-19-2006, 04:27 PM   #2
redmaro
This is probably a dumb question but i ask because I've seen them at 0 when idleling and mine is all the way down.
Old 09-19-2006, 09:45 PM   #3
Isphius
Isphius's Avatar
It should actually be negative, And go up to 0 or just below when you blip the throttle. N/A motors run on vaccum (negative pressure) all the time, And your turbo should while cruising or accelerating slow at low rpms. If its making boost at idle you have some sort of problem lol.
Turbo lag question. rnoswal MKIII Supra 6 02-12-2006 05:42 AM
