Old 09-22-2006, 05:58 PM   #1
Supraman
Supraman is on a distinguished road
Default starting problem
I have a 1991 Supra Turbo I recently did some upgrades (hg, turbo, fuel injection, maf, new starter, manual transmission R154, walbro fuel pump) When I went to start it nothing happened so I replaced the starter relay cause I could not hear it click. Tried to start it again after installing ithe new one, again nothing. So I checked all fuses I could find. All looked good. So does anyone have any ideas what I might have missed (in line fusable link maybe another relay that might need to be replace). I also checked the ignition switch. Seems just fine. And I cant find a wire diagram for this car. So Im kind of stuck. Thanks for any help.
Supraman is offline   Reply With Quote
Old 09-22-2006, 07:14 PM   #2
mizuboi
mizuboi is on a distinguished road
this might sound stuipd to you but have you checked your battery?it might be dead or your grounds?
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 09-22-2006, 07:18 PM   #3
Supraman
Yes I did check the battery it was fully charged. I would be happy if it was that simple. And trust me there are no stupid questions.
Old 09-23-2006, 05:06 AM   #4
jfunez
jfunez's Avatar
first of all..was the battery tested properly? a battery can be fully charged at 12 to 14 volts but with a bad cell, it can only have 75 cold cranking amps.. which is not enough umph to turn the starter and consequently the flywheel.
CCA is what starts your car not volts.
another thing you can do is hook up a test light at the signal wire at the starter (thats the small wire) and have an ASS.........sistant hit the switch. it should light up.
Old 09-23-2006, 12:59 PM   #5
Supraman
It was tested at the local performance shop. They always test my stuff. They said it was working fine even under load.
Old 09-23-2006, 02:22 PM   #6
justin1642
justin1642's Avatar
well i know the factory alarm causes the car not to turn over at all so i don't know if your alarm went off or like on mine if i kept turning the key to on and then off a few times without starting it then it triggers the alarm without the alarm even going off. but that could just be my car i don't know. also if any of your wires are corroded it will have a hard time starting. hopefully you figure it out good luck.
Old 09-23-2006, 03:55 PM   #7
rnoswal
rnoswal's Avatar
There is a starter relay behind the passenger kick board. The starter ockout switch might be unplugged if it is a manual. I it used to be an automatic trans then you may need to disable the auto lockout (only starting in park). Get someone to turn the key and check the wire that goes to the starter solenoid then make sure the main power cable does in fact have power to it.
Good luck and let us know how it goes.
Russ
Old 09-25-2006, 01:30 PM   #8
Supraman
I got it. Some how the wire running to the starter had been grounded some how, so I just ran a new wire, now it starts just fine. Thanks for the help.
Old 09-26-2006, 09:53 PM   #9
supraman121
Default problem starting
Russ
Mine has a hard time starting you have like 3 relays under the kick panel over there that other two control fuel and the other one controls a bunch of misc. stuff but dont make the mistake of replacing the fuel one that is like 150 dollars of something.. my car dosent start half the time but when i run into that problem i get up under neith the steering wheel and disconnect it for like a day then reconnect it if the cars starts i would look into replacing the alarm
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
mysterious starting problem stevanom MKIII Supra 7 11-14-2006 08:50 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
problem starting damdog05 MKIII Supra 0 08-05-2006 02:44 AM
i have a starting problem johndawn MKIII Supra 4 02-16-2006 01:16 AM
