I have a 1991 Supra Turbo I recently did some upgrades (hg, turbo, fuel injection, maf, new starter, manual transmission R154, walbro fuel pump) When I went to start it nothing happened so I replaced the starter relay cause I could not hear it click. Tried to start it again after installing ithe new one, again nothing. So I checked all fuses I could find. All looked good. So does anyone have any ideas what I might have missed (in line fusable link maybe another relay that might need to be replace). I also checked the ignition switch. Seems just fine. And I cant find a wire diagram for this car. So Im kind of stuck. Thanks for any help.
#2 | |
this might sound stuipd to you but have you checked your battery?it might be dead or your grounds?
my modifications blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs comming: new fly wheeel and not running for sale car parts for sale misc. things for sale Quote:
![]() stole it from sm |
Yes I did check the battery it was fully charged. I would be happy if it was that simple. And trust me there are no stupid questions.
first of all..was the battery tested properly? a battery can be fully charged at 12 to 14 volts but with a bad cell, it can only have 75 cold cranking amps.. which is not enough umph to turn the starter and consequently the flywheel.
CCA is what starts your car not volts. another thing you can do is hook up a test light at the signal wire at the starter (thats the small wire) and have an ASS.........sistant hit the switch. it should light up. |
It was tested at the local performance shop. They always test my stuff. They said it was working fine even under load.
#6 |
well i know the factory alarm causes the car not to turn over at all so i don't know if your alarm went off or like on mine if i kept turning the key to on and then off a few times without starting it then it triggers the alarm without the alarm even going off. but that could just be my car i don't know. also if any of your wires are corroded it will have a hard time starting. hopefully you figure it out good luck.
Starting problem - Gas conversion ??? | eggybread | MKIII Supra | 9 | 12-11-2008 01:48 PM |
mysterious starting problem | stevanom | MKIII Supra | 7 | 11-14-2006 08:50 PM |
1986.5 Starting Problem | supraman121 | MKIII Supra | 4 | 09-03-2006 03:51 AM |
problem starting | damdog05 | MKIII Supra | 0 | 08-05-2006 02:44 AM |
i have a starting problem | johndawn | MKIII Supra | 4 | 02-16-2006 01:16 AM |
