can any one tell me where this goes.( the line with the screw in it) if you take off the alternator there is a t-joint that it connects to right below the intake manifold. but i dont see anywhere that it can connect to. any help would be appreciative. its on a 90 turbo supra.
you're gonna need to tell us where that's coming from
here's a vacuum diagram anyhow.. ![]()
hope this helps. the diagram that you posted doesn't show the line that i am trying to find here is where it comes out.
that is more than likely coming from 17650 from the vacuum diagram
thanks for the respond.
where exactly is the 17650 (VSV)? |
#6 |
oops sorry
#7 |
at about 7 o clock on the diagram to the one that has the green circle is the front vsv
it has the numbers written on it also
Where is this vacuum line saposed to connect to? | mkiiisupra | MKIII Supra | 15 | 07-15-2010 05:15 AM |
Vaccum tube ID help | bowhunter951 | Non-Generation Specific Questions | 6 | 10-05-2008 12:55 PM |
Vacuum line routing to HKS SSQV? | mkiiisupra | MKIII Supra | 8 | 02-06-2008 05:29 AM |
Blown line going to EGR | Morty | MKIII Supra | 11 | 01-13-2008 12:42 PM |
Fuel line problem | Damian | MKIII Supra | 1 | 07-23-2005 10:22 PM |
