Old 09-26-2006, 10:51 PM   #1
burton51m
burton51m's Avatar
Question Heater
where i live it is getting colder and colder....especially in the morning.
in the mornings i let my car warm up the head out. i noticed the heat in my car wasnt as strong as it usually is and it eventually died off after about 10 minutes (i get room temp air blowing in my face).
the next day the same thing happened -hot air for a while then just cold air after ~10 minutes.
my air conditioning already doesnt work; now my heat is going
anybody know what is wrong?
Old 09-26-2006, 11:53 PM   #2
sounds like your heater unit has some dry joints
you could try resoldering them or just get a known good second hand one
Old 09-27-2006, 02:10 AM   #3
If the water valve is fully open, then I'd say the core is almost plugged up. After some air passes over it, there is not enough hot water to keep it warm.
Run the blower on low speed, and use recirc air, until you can get it fixed.
Old 09-27-2006, 10:10 PM   #4
burton51m
burton51m's Avatar
ok thanks
i noticed that it it only works when i am driving. i sit and idle in the parking lot for about 10 minutes (after 10 min of driving)and that is when i lose heat.
Old 09-28-2006, 05:24 AM   #5
Not enough coolant flow thru the core. What thermostat are you running?? I use a 180* in the summer, and a 195* in the winter.
That 15* makes a lot of difference in the heater operation, but not in the overall engine temp, as it never get close to 1/2 on the gage.
That is because I'm using the heater, which cools the engine too.
Old 09-28-2006, 07:26 PM   #6
Cool
i think it's the heater switch vsv on the firewall
http://www.ddmcse.com/turbo/heatervs.htm
Old 09-29-2006, 01:15 AM   #7
burton51m
burton51m's Avatar
stock??
what is the stock temp for the thermostat
mine is right below the midpoint
i have never had a problem with this in the past winters so i dont know what it is..
thanks for the info ddmcse, ill try that.
Old 09-29-2006, 01:47 AM   #8
stock thermostat is 195*. But that is also for emmision control. My VSV was bad, so I just hook the vacuum hose directly to the water valve in the winter, and remove (and plug with golf tee) in summer.
Hook the vacuum hose direct and see if heat improves.
180* thermo seems to be ideal.
Old 09-29-2006, 05:15 AM   #9
1988gte
did it last year, works like a champ, i get hot air even at idle.
Old 10-01-2006, 07:18 PM   #10
burton51m
burton51m's Avatar
do you do it like this? What about the extar hose that i have circled? take it off?
i just dont wanna screw anything up...
excuse my messy engine bay its in the works...
Heater hose locations suprabahamut MKIII Supra 4 12-16-2008 10:07 PM
location of heater core MKIIIBeast MKIII Supra 1 02-25-2008 02:00 PM
heater problem..... cold like heck... hangsupra MKIII Supra 9 01-28-2007 05:35 PM
Heater By-Passing...Your Thoughts mrnickleye Non-Generation Specific Questions 2 05-03-2006 03:06 PM
heater answers?? 1988gte MKIII Supra 14 12-05-2005 07:07 PM
