-   -   Heater (http://www.toyota-supra.info/forums/mkiii-supra/6190-heater.html)
burton51m 09-26-2006 10:51 PM
Heater
where i live it is getting colder and colder....especially in the morning.
in the mornings i let my car warm up the head out. i noticed the heat in my car wasnt as strong as it usually is and it eventually died off after about 10 minutes (i get room temp air blowing in my face).
the next day the same thing happened -hot air for a while then just cold air after ~10 minutes.
my air conditioning already doesnt work; now my heat is going
anybody know what is wrong?
suprra_girl 09-26-2006 11:53 PM
sounds like your heater unit has some dry joints
you could try resoldering them or just get a known good second hand one
mrnickleye 09-27-2006 02:10 AM
If the water valve is fully open, then I'd say the core is almost plugged up. After some air passes over it, there is not enough hot water to keep it warm.
Run the blower on low speed, and use recirc air, until you can get it fixed.
burton51m 09-27-2006 10:10 PM
ok thanks
i noticed that it it only works when i am driving. i sit and idle in the parking lot for about 10 minutes (after 10 min of driving)and that is when i lose heat.
mrnickleye 09-28-2006 05:24 AM
Not enough coolant flow thru the core. What thermostat are you running?? I use a 180* in the summer, and a 195* in the winter.
That 15* makes a lot of difference in the heater operation, but not in the overall engine temp, as it never get close to 1/2 on the gage.
That is because I'm using the heater, which cools the engine too.
ddmcse 09-28-2006 07:26 PM
i think it's the heater switch vsv on the firewall
http://www.ddmcse.com/turbo/heatervs.htm
burton51m 09-29-2006 01:15 AM
stock??
what is the stock temp for the thermostat
mine is right below the midpoint
i have never had a problem with this in the past winters so i dont know what it is..
thanks for the info ddmcse, ill try that.
mrnickleye 09-29-2006 01:47 AM
stock thermostat is 195*. But that is also for emmision control. My VSV was bad, so I just hook the vacuum hose directly to the water valve in the winter, and remove (and plug with golf tee) in summer.
Hook the vacuum hose direct and see if heat improves.
180* thermo seems to be ideal.
1988gte 09-29-2006 05:15 AM
did it last year, works like a champ, i get hot air even at idle.
burton51m 10-01-2006 07:18 PM
do you do it like this? What about the extar hose that i have circled? take it off?
i just dont wanna screw anything up...
excuse my messy engine bay its in the works...
.http://i8.photobucket.com/albums/a8/...ence/extra.jpg
