Old 09-26-2006, 02:23 PM   #1
grygst76
grygst76 is on a distinguished road
Default Running rich!
went to get my inspection sticker, she is all stock except cold air, anyways I failed, we have a rolling test and my HC's were thru the roof, our limit is 2.0, I did 3.9. anyone have any ideas why she is running so rich??
89 Turbo, no mods yet
5 speed mbc to 10psi
grygst76 is offline   Reply With Quote
Old 09-27-2006, 02:15 AM   #2
mrnickleye
mrnickleye's Avatar
HC is raw, unburned fuel.
what were the CO% #s??
-very high CO% will mean running too rich
Possible areas:
-very rich mixture (black smoke)
-Engine misfires (very likely)
-cat converter bad
Rolling Test?? you mean dyno??
Old 09-27-2006, 03:32 AM   #3
Murd
Guessing he means the 25mph test. Car runs under load and they check the exhaust again, like at idle.
Old 09-27-2006, 11:41 AM   #4
grygst76
co2's were high as well 30.00 is the limit, I had 23.31. really sucked...
Old 09-28-2006, 05:36 AM   #5
mrnickleye
mrnickleye's Avatar
I'd get those CO% #s down for a starter. O2 sensor, AFM, other things.
Old 09-28-2006, 11:36 AM   #6
grygst76
I put the new o2 sensor in and can feel the change already, but i reset the ecu and now when I am over 2000RPMS and push in the clutch, she stalls. And I hear a fluttering from the BOV, thats normal right since it is stock?? also my idle is finnally staying where it should be, before the new o2 it would be around 800 or more.
Low idle and running rich Mitshiko MKIII Supra 23 10-10-2009 02:12 AM
Running Rich! Help needed mc_p0pe MKIII Supra 13 05-23-2008 12:31 AM
Running Sooooooo Rich! Help! godgaveussid MKIII Supra 4 08-29-2007 08:46 PM
Running very rich OmeGa MKIII Supra 3 12-09-2006 09:59 PM
fixed the running rich problem djalkyd MKIII Supra 6 05-04-2006 04:31 AM
