Old 10-05-2006, 06:05 PM   #21
west_side_supra
west_side_supra's Avatar
Default Yipee!!
well id like to say thanks for everyones help once again, i would also like to put that it ended up being a missfireing, 4 spark plugs were F$%ked up and my wires where pretty shot, put some new ones in last night and its running like a champ, my performance shop also plugged the 3000 pipe up with a lug nut, and left the other one to the air filter unplugged and it doesnt bog or cut nothing runs like a champ, and i love that great feeling of pushing on the throttle fully
and now the BOV is even working. i think i need more boost though the BOV is a low pitch sound, like someone with their mouth wide open and blowing out still better than it was
Old 10-05-2006, 08:01 PM   #22
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
I hearsd about a guy who put a modified Supercharger on his 89 supra. Is that possible he was in our car club. and could beaqt alot of peopel so i dunno.Is it really possible?
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-05-2006, 11:10 PM   #23
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
you must block the intake one or it will suck in unmetered air you will run lean and blow it up
so block that up
Pics of my build.
Do a diagnostic first!
Old 10-06-2006, 06:07 PM   #24
west_side_supra
thats the weird thing its not running lean at all, its running like it did when i bought it. perfect. exhaust smells great well not really but normal at least. ill put a gauge in there to see how its running
Old 10-06-2006, 09:57 PM   #25
nelly26
nelly26 is on a distinguished road
hi you need cut off recirculation pipe where the old bov use to be, i can take picture off mine to show how it should be if you want and also you have not got the right hks kit because the pipe that come with hks kit should replace the hole rubber pipe for intake
nelly26 is offline   Reply With Quote
Old 10-06-2006, 10:03 PM   #26
suprra_girl
7M POWAH! ;)
how he had it was fine
3000 pipe blocked and intake blocked
i have told him to change how the "performance shop" told him to route it as now he has a leak in the intake and will be running lean
hopefully he has corrected this
also.. once again, if you think the bov might be the cause
wiggle the damn thing... if it moves.. it's loose and you need a bigger o-ring which goes inside the flange
altho it may not be the way most do it, its still going to work
altho pics of yours would be nice anyhow
Pics of my build.
Old 10-09-2006, 08:35 PM   #27
west_side_supra
Default ok
so wait you want me to to block both the 3000 and the intake, or else my block will go bomb? my Bov dont wiggle anymore cause i couldnt find a bigger o-ring so i just used some silicone to seal up the bov flange. so there is no leaking there, so far it is running great, no cutting out exhaust smells somewhat fine, gas mileage still seems right, nothing wrong running at all, i still havent tryed to block that intake pipe since the repair, ive got an extra lugnut to block it off so ill give it a try.
oh and please do post some pictures of your BOV setup
Old 10-10-2006, 05:43 AM   #28
suprra_girl
7M POWAH! ;)
if you have a hole venting/sucking to atmosphere in your intake you MUST block it
here's how the list works
air filter
afm
intake
turbo
intercooler
throttle body
intake manifold
combustion
now after the air filter you have the afm (the air METER device) it measures how much air is coming into your engine so it can squirt in the right amount of fuel for the air that you sucked in
BUT
you have an extra hole in your intake AFTER your air metering device which when your turbo sucks in air now it is not only sucking air from the filter it is now sucking in unmetered air
too much air = not enough fuel
the ecu is only putting in enough fuel to support the air it metered not the air you sucked in afterward
so to sum it all up
answer = detonation = pitting in the pistons = (depending on boost) meltdown of internal engine parts = new engine
not a fun exercise
silicon on those sorts of parts is not recommended.... you can get a new o-ring from anywhere, you just take them yours and ask for a thicker one but same diameter
so are you still having misfiring problems or are they gone?
Pics of my build.
Old 10-11-2006, 07:51 PM   #29
west_side_supra
wow that was a great explaination to how that all works, i understand it all now. i did look for a thicker o-ring and i coulndt find jack. thats why i siliconed it, its not mis-fireing/bogging/cutting at all, its driving great, but ill plug up that pipe with the lug nut that the shop forgot to take out of my engine compartment after they were done now for one last question, if i was to get a boost controller how far would i be able to get my stock turbo to push, its only doing 6-7 lbs right now. and also what would be a good boost contoler to get, and im also kinda on a budget right now so maby a cheaper one also thanks again
Old 10-11-2006, 11:37 PM   #30
j3pz
fyi ct26 arent for high boost, after like 13, 14 psi they start to become inefficient. also any manual boost controller would work, unless you want something you adjust on the go or electronic or high priced, w/e. sure you can find on ebay...
Audio and a lot of other things wrong with car bluemeate MKIII Supra 4 05-18-2010 07:07 PM
Wrong oils everywhere Gunnar MKIII Supra 1 01-08-2008 04:08 PM
My fenders look wrong Kristian_Wraae Non-Generation Specific Questions 14 05-07-2007 03:20 PM
intake manifold has coolant what did i do wrong? 91toy supra MKIII Supra 6 09-16-2006 02:46 PM
