Old 10-03-2006, 03:38 AM   #11
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Originally Posted by Murd
New TSRM went up a few weeks ago I believe. Good luck on the car!
LOL Thabnks, very much. Anyone have any luck wh the LS400 AFM?
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-04-2006, 08:00 PM   #12
ravenmaster
Bump. Same question as above.
BTW for the coilovers versus TEMS, Coilovers are a helluva alot more expensive check HKS' out http://www.hksusa.com/products/?id=716&rsku=5281 where as to install the TEMS systems is $400. sooo im gunna go with tyhe tems system.
Old 10-04-2006, 09:46 PM   #13
Murd
Here's another option..
http://www.suprastore.com/tesscotosu.html
or for the illumina II's
http://www.suprastore.com/tokiliistrut.html
About double the price for coil overs. But about 1/2 the cost of the HKS ones.
Old 10-04-2006, 09:52 PM   #14
Murd
http://cgi.ebay.com/ebaymotors/Lexus...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/LEXUS...QQcmdZViewItem
three different listings, three different prices.
Old 10-05-2006, 02:21 PM   #15
ravenmaster
Murd you are the man. Thank you so much. (BTW if any english is misspelled I apologize. Still learnming)
Old 10-05-2006, 02:45 PM   #16
ravenmaster
And I ordered the Illumina II's, found the Tems computer and ripped it out of a 1990 Toyota Supra that was wrecked. But the comp tested fine. Unfortunatly the servo motors were already yanked. The computer fits perfectly in that back area panel next to the light panel. So thats good. i always wondered why that panel was there considering there was nothing under it, there was mounted higher up but not directly there. Whatever, the wiring is being a pain in my arse though.
Old 10-05-2006, 05:05 PM   #17
Isphius
Isphius's Avatar
For the record, im selling my entire TEMS system when i get around to taking it out. Which is all the parts required to make a non-tems car into one.
Old 10-05-2006, 05:06 PM   #18
Isphius
Isphius's Avatar
And BTW, what is a 3jz?
Old 10-05-2006, 05:15 PM   #19
ravenmaster
LOL my bad my keyboard is still set up on german so i keep hitting 3 when i mean to hit 1. Basically all i need from you if you want to sell it to me is the Servo motors in the engine bay, the switch thingy inside the cockpit, and i want an extra computer as the one i got was in a wrecked supra that was exposed to weather conditions. or are you saying your going to convert your own?
Old 10-05-2006, 09:37 PM   #20
burton51m
burton51m's Avatar
3 turbos on a 1jz...duh
TEMS Problem! 88 MARK3 Non-Generation Specific Questions 13 11-08-2018 10:41 PM
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
non tems 1988gte MKIII Supra 9 04-19-2006 09:38 AM
