#2 |
7M POWAH! ;)
first things first... the motor is called a 1jzgte not 1jzgtte
things you must also learn engine types/models examples M series engine JZ series engine 1G series engine none of these engine numbers/letters are the same... i.e.. you cannot interchange parts so to answer your question can 7M parts be used on a 1JZ, the answer is no can 2JZ parts be used on a 1JZ... yes your hardest part for the gearbox is finding a jz bellhousing (not sure if you guys get these over there, more than likely do, but you could get a w58 bellhousing from a jza80 non turbo mk4) otherwise you would be searching in japan for an jz series bellhousing for a r154 good luck with your search in my biased opinion i would hope that the 7m would prevail ![]()
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
7MGTE to 7MGE | karu | MKIII Supra | 4 | 10-22-2010 07:22 AM |
7mgte or 1jzgte parts | sr_xaiko | MKIII Supra | 5 | 08-14-2006 03:56 PM |
1JZGTE or 7MGTE ?? | faheemo | MKIII Supra | 2 | 05-30-2006 07:59 PM |
1jzgte vs 7mgte | 86.5_supra | MKIII Supra | 4 | 05-11-2006 07:49 PM |
7mgte or 1jzgte | gpgtp_22 | MKII Supra | 1 | 01-29-2006 08:27 AM |
