Old 10-06-2006, 10:27 PM   #21
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
ah hah
what you encountered was speed cut
you'll find when you drop the ecu that there is a pink wire and you have a little black box intercepting it
get that lead out of your foot
edit: any ideas what git stands for? just curious
but also odd... is yours an import? rhd or lhd?
uk cars i believe don't have speed cut but i guess maybe your ecu has been changed as some stage
if you do get the chance to drop your ecu would you be able to write down the part number on the ecu for me... i have a friend with a complete parts list so i can determine the originality of your ecu in particular
the speed cut is usually about 120mph
Pics of my build.
Do a diagnostic first!
Old 10-06-2006, 10:41 PM   #22
nelly26
nelly26 is on a distinguished road
mine is uk spec rhd 5sdm 1992 i also have a 1990 aswell auto i have been told gear box has gone i dont have kick down any more and when put into drive it stalls and ecu light comes on
nelly26 is offline   Reply With Quote
Old 10-06-2006, 10:54 PM   #23
suprra_girl
7M POWAH! ;)
ahh i would say being rhd that you will have speed cut then
to save you some money... do your own diagnostic come back and post your codes and we'll see whats up with ya check engine light
maybe post a new thread saves hijacking gomez's lol
Pics of my build.
Old 10-07-2006, 03:01 AM   #24
gomezmk
gomezmk is on a distinguished road
My car is a 5 speed. The cutout is a fast cut something like a rev limiter. I 'm leaning towards buying a hks fuel cut denfencer.
gomezmk is offline   Reply With Quote
Old 10-07-2006, 03:04 AM   #25
gomezmk
my car is a 5 speed and it does it in all gears. it's a fast cut out.
Old 10-14-2006, 04:22 AM   #26
gomezmk
Hello everybody, I think I might know what the problem is. My bov is leaking big time. I have a cheap bov that is very similar to the turbo xs bov. I changed the position of the bov so the boost from the 3000 pipe is pushing on the side of the piston instead up on the piston thus compressing the spring. It still leaks but not nearly as much as it did the other I had it routed. When I test drove it , it pulled amazing at high rpm but now it cut out 5,500 rpm instead of the usual 5,000 rpm. I'm hoping if I get a really good bov, it might fix it.
Old 10-20-2006, 12:12 AM   #27
gomezmk
I installed the new bov, it helped out but still didn't fix it, it still cuts out at 5,500 rpm. I rev the engine up in neutral and it cutouts at 5,500 rpm so I have no clue why it would do that! I did do a na to turbo swap on this car.
Old 10-22-2006, 10:37 PM   #28
gomezmk
ok I finally found the problem with the cuttout at 5,500rpm. I took out the air flow sensor and it was covered in junk, I cleaned it really good and now I can rev it to 6,000rpm. The think is from 5,500 rpm to 6,000 it pulls really slow.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
