Old 10-04-2006, 05:49 AM   #1
gomezmk
gomezmk is on a distinguished road
Default big problem
I have a 1987 supra turbo, mods are 2.5 inch inner cooler pipe, mbc 10psi, 3 inch full exhaust, adustable fuel regulator, no boost leaks for sure, foam air filter. Engine runs perfect, pulls ok under boost up untill I hit 5,000 rpm then the motor just starts back firing like crazy. I have a super monitor on the dash to check codes by pressing the buttons it will tell me the codes and the dash says, eng- ok. I don't know what to do. Am I crazy to think my foam filter is restricting air. Help me!!!!!!1
gomezmk is offline   Reply With Quote
Old 10-04-2006, 08:42 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
sure you're not hitting rev limiter (oddly enough) early?
is it fast backfiring or consistent or just all over the place?
what codes did you pull, in your post do you mean the codes were clear?
Pics of my build.
Do a diagnostic first!
Old 10-04-2006, 06:14 PM   #3
gomezmk
The wierd thing is that when my engine was all stock at 6 psi of boost, it never did it that bad from 5,000 rpm to six, it use to just pull very slowlly from 5 to 6 so thats why I think my foam filter might be the problem because since I'm running more psi now more air has to flow through my filter which is probably now restricting the air even more. I have completelly no codes existing in my diagnostics check.
Old 10-05-2006, 10:31 PM   #4
gomezmk
I ran the car without the filter and I noticed a torque increase but still would cutout at 5,000 rpm. I remembered that I installed bosch platium spark plug and I did researh and learned that they are no good for turbos so I installed ngk plugs, i'll see what happens now.
Old 10-05-2006, 11:40 PM   #5
gomezmk
well i ran it with new plugs and it still does it wtf!!!!!!!!!!!!
Old 10-06-2006, 06:37 PM   #6
gomezmk
Next is to try to readjust the tps, thats all I can think of.
Old 10-06-2006, 08:25 PM   #7
suprra_girl
7M POWAH! ;)
i think if it was the tps it would throw a code of some sort
can you describe the noise any better?
is it a slowish type cut or is it really fast?
is it the same cut as with the old plugs? or has the sound changed
Pics of my build.
Old 10-06-2006, 09:42 PM   #8
nelly26
nelly26 is on a distinguished road
have you had fuel cut off bypassed if not, if you exceed the psi on turbo more than 10 psi it will cut out so will have to get the ecu chipped to bypass
nelly26 is offline   Reply With Quote
Old 10-06-2006, 09:49 PM   #9
suprra_girl
7M POWAH! ;)
^ i'm confused
what has that got to do with his misfiring?
and just for future reference you can't "chip our ecu's" as such
fuel cut is not boost/psi referenced it is by hz which is what our afm measures and the hz frequency of fuel cut can vary it is generally between 11-13 for stockish vehicles and can be very low for high air flow vehicles
Pics of my build.
Old 10-06-2006, 10:03 PM   #10
nelly26
when i had my boost put to 15 psi i found when it got above 10 psi she would cut out and miss fire i had her chipped and has been runing sweet
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
