code 11
for an 88 turbo what does code 11 mean and how do you fix it.
thanks |
code 11
momentary interruption of power supply to ecu you have crappy grounds ;) check the grounds on the intake manifold :) unbolt them, check them, make sure they're still well connected, clean the surfaces, bolt them back on make sure your battery terminals are good and not corroded http://supra.co.nz/87tsrm/EFI/efi30.htm |
| All times are GMT. The time now is 08:31 AM. |
