Old 10-09-2006, 07:57 PM   #1
brandonsupra
brandonsupra is on a distinguished road
Default types of gaskets?
I see there are a few different types of gaskets you can get. What are the differences (good and bad) between metal, graphite, or other types of gaskets? I am curious because I see an entire gasket set on ebay for cheap, but they're all graphite. Opinions? Thanks guys.
brandonsupra is offline   Reply With Quote
Old 10-11-2006, 12:12 AM   #2
ZauggIt1
ZauggIt1's Avatar
ZauggIt1 is on a distinguished road
If your going for more boost, then buy the metal head gasket. All the others really dont do much, just the head. If you get a metal head gasket, with more boost, its almost a must to buy some ARP head studs, and torque to 115ft lbs. if not increasing boost, i would highly recommend the kit from felpro, very good gasket. The only thing is that you will pay a little more for it. Go to your local parts store to find out.
Drive it like you stole it!!!
ZauggIt1 is offline   Reply With Quote
Old 10-11-2006, 01:18 AM   #3
j3pz
[QUOTE=ZauggIt1] torque to 115ft lbs. QUOTE]
thats a little over kill if you dont plan on high boost. most ppl torque the head to about 80 ft lbs.
Old 10-11-2006, 01:25 AM   #4
ZauggIt1
ZauggIt1's Avatar
Yeah, thats what i thought, but if you think about it a little more, ARP says with studs you must torque more than bolts. especially if its a alum. head. ARP says 115 ft lbs
Old 10-20-2006, 06:15 PM   #5
brandonsupra
Right, so metal if I plan on boosting. But what if I don't? I'm not worried about torquing and what not more along the lines of actual gasket type. Are graphite good for non-boosting applications?
Old 10-20-2006, 08:07 PM   #6
tone loc
tone loc's Avatar
you should just go metal anyway so you dont have to worry about it (do it right the first time) or if you want like a quick fix or are short on money go with the toyota oem one
Valve cover gaskets scruffboy Non-Generation Specific Questions 2 04-12-2008 09:27 PM
Valve cover gaskets vancouver874 Non-Generation Specific Questions 7 08-14-2006 07:28 PM
gaskets cooley346 MKII Supra 2 02-28-2006 06:19 AM
head gaskets cody_18_06 Non-Generation Specific Questions 2 11-08-2005 02:37 PM
