Old 10-10-2006, 01:42 PM   #1
frostburn
frostburn is on a distinguished road
Default please help me if u can
ok well i already have a post of my head gasket being gone... now... i was woundering if anyone knows a way i could drive it without it over heating every 30 seconds i know im indangering my tranny but im replacing it anyways ... i tried the good old lease rad cap loose but all that does it cause skinky smoke ... any advice would be AMAZING thats alot.
frostburn is offline   Reply With Quote
Old 10-11-2006, 01:12 AM   #2
j3pz
over heating can do more damage than just to your tranny so you might wanna stop driving it
Old 10-11-2006, 04:23 AM   #3
tone loc
tone loc's Avatar
^^^ yeah id fox wit that
Old 10-11-2006, 04:53 PM   #4
nelly26
nelly26 is on a distinguished road
Angry
if you keep driving with hgb it cost you more bucks to repair so i would agree wth the two
nelly26 is offline   Reply With Quote
Old 10-12-2006, 12:56 AM   #5
frostburn
figured out the reason for my overheating wasnt my head gasket atall but was a decayed rad hose behind the engine it was spraying all my fluids out like a sprinkler at high speeds, i cut off the decade spot and got the hose to reach byut just bairly and replaced the clamps with wider and thicker clamps that can hold alot more presure also .... filled my rad back up and it took about 5L!, of antifreeze.... if anyone can tell me the best way to detemine a exhaust leak that would be cool... also a boost leak although i just got a boost gage tonight and havent put it in yet... if anyone is selling a boost controler contact me on this post manual is in mind but a digital is acceptable.
Old 10-13-2006, 12:28 AM   #6
rnoswal
rnoswal's Avatar
WOW, replace that hose with a new one! If you just stretched out the old one it will soon be leaking again! In fact replace them all along with the clamps.
Have someone put a rag over the exhaust exit and with the car up on jack stands, listen for any leaks. Place your hands close to the gasket joints in the exhaust system to feel for any air leaks, but don't touch it, unless you just started it up cold. If you block off the exhaust and it dies pretty quick then it is a relatively good sealed system.
Russ
Old 10-13-2006, 02:40 AM   #7
jfunez
jfunez's Avatar
around $750 so far for me, thats including :
head machined,cleaned and presure tested
turbo gaskets
miscelanious gaskets
arp studs
titan motorsports MLSteel gasket
And I still havent started to put it back together....
Old 10-13-2006, 03:29 AM   #8
nelly26
Unhappy
thats cheap when hg went i had done at garage it cost me 980 pounds and only blue print hg fitted but been fine at just need to sort out clutch and turbo more money cool
Old 10-13-2006, 02:26 PM   #9
supra1985turbo
supra1985turbo is on a distinguished road
You should also se some black carbon build up around the area of the exhaust leak.
1985 celica supra upgrading to street/drag well mainly drag. Have complete HKS T4 turbo kit, electronics and all, Getting head port and polish with HKS 264 cams, and port and polished intake with 6 extra injector bungs. Eagle or crower rods? I just bought a 1990 MA70 n/a .
supra1985turbo is offline   Reply With Quote
