-   -   please help me if u can (http://www.toyota-supra.info/forums/mkiii-supra/6352-please-help-me-if-u-can.html)
frostburn 10-10-2006 01:42 PM
ok well i already have a post of my head gasket being gone... now... i was woundering if anyone knows a way i could drive it without it over heating every 30 seconds i know im indangering my tranny but im replacing it anyways ... i tried the good old lease rad cap loose but all that does it cause skinky smoke ... any advice would be AMAZING thats alot.
j3pz 10-11-2006 01:12 AM
over heating can do more damage than just to your tranny so you might wanna stop driving it
tone loc 10-11-2006 04:23 AM
^^^ yeah id fox wit that
nelly26 10-11-2006 04:53 PM
if you keep driving with hgb it cost you more bucks to repair so i would agree wth the two
frostburn 10-12-2006 12:56 AM
figured out the reason for my overheating wasnt my head gasket atall but was a decayed rad hose behind the engine it was spraying all my fluids out like a sprinkler at high speeds, i cut off the decade spot and got the hose to reach byut just bairly and replaced the clamps with wider and thicker clamps that can hold alot more presure also .... filled my rad back up and it took about 5L!, of antifreeze.... if anyone can tell me the best way to detemine a exhaust leak that would be cool... also a boost leak although i just got a boost gage tonight and havent put it in yet... if anyone is selling a boost controler contact me on this post manual is in mind but a digital is acceptable.
rnoswal 10-13-2006 12:28 AM
WOW, replace that hose with a new one! If you just stretched out the old one it will soon be leaking again! In fact replace them all along with the clamps.
Have someone put a rag over the exhaust exit and with the car up on jack stands, listen for any leaks. Place your hands close to the gasket joints in the exhaust system to feel for any air leaks, but don't touch it, unless you just started it up cold. If you block off the exhaust and it dies pretty quick then it is a relatively good sealed system.
Russ
jfunez 10-13-2006 02:40 AM
around $750 so far for me, thats including :
head machined,cleaned and presure tested
turbo gaskets
miscelanious gaskets
arp studs
titan motorsports MLSteel gasket
And I still havent started to put it back together....
nelly26 10-13-2006 03:29 AM
thats cheap when hg went i had done at garage it cost me 980 pounds and only blue print hg fitted but been fine at just need to sort out clutch and turbo more money cool
supra1985turbo 10-13-2006 02:26 PM
You should also se some black carbon build up around the area of the exhaust leak.
