Old 10-12-2006, 06:56 PM   #1
redmaro
Default Shifting in a automatic?
I always here some of my friends say they manually shift gear in their automaic transmission cars. I've heard this shouldent be done since it can mess-up your tranny.
Is this true?
Old 10-12-2006, 07:06 PM   #2
burton51m
burton51m's Avatar
i dont c the point of it...
its not gonna make u faster
if u want to shift do a tranny swap or go buy a manual car..
Old 10-12-2006, 07:58 PM   #3
tone loc
tone loc's Avatar
i think its called a tiptronic and you can have your car in drive like an auto but if you want to controll it you put the shifter in a certain spot and there is + and - and you just move it up or down to change gears.
Old 10-12-2006, 10:01 PM   #4
ravenmaster
ravenmaster's Avatar
Youjust described steptronics. Tip is wht Formula 1 cas use.
1988 Toyota Supra Turbo Targa
Old 10-12-2006, 10:41 PM   #5
tone loc
tone loc's Avatar
i know my friend has one in his acura and my boss has one in his vw
Old 10-12-2006, 10:59 PM   #6
kwnate
Automatics shift for you. Let them.
/Thread
Nate
Old 10-13-2006, 12:10 AM   #7
rnoswal
rnoswal's Avatar
Floor it and see when it shifts. If you feel the power drop off before the shift or the car keeps pulling but shifts too early, then you may want to shift it manually. I think the auto turbo is supposed to be faster than the manual except for getting off the line.
Russ
Old 10-13-2006, 02:35 AM   #8
Isphius
Isphius's Avatar
Automatic transmissions work by shifting after your car falls out of its powerband, And it can tell more acuratley than you can, Unless you have a messed up transmission or a motor swap, etc (like say, putting a motor with a 9k rpm redline with the a340, its still going to shift at like 6000 rpms because it has a governer as a safety) And the vws, acuras, new clipse, new maxima, etc and other cars have that tiptronic, auto-manual crap, It is just a fancy name for an automatic with a + and - for the gears. Its totally pointless. I went to test drive an elcipse gt and the salesman was trying to show it to me, and i just left it in D. oh well. The mr2 spyder like mine came with a 6 speed sequential transmission, Which a lot of people thought was an auto-manual thing, But its a real sequential 6 speed, It just has an automatic clutch and assisted shifting. But, The shifts are always the same whether driving slow or trying to drag race someone, Which makes it kind of kill the cars performance. You can tell by the massive difference in 0-60 between the 5 speed and 6/sequential. The good part about sequential transmissions is the massively fast shift time...like on a motorcylce. Seems kind of pointles to me...
Old 10-14-2006, 03:00 AM   #9
redmaro
My friends are doing this kind of shifting in regular auto transmissions. But I know it dosent make you faster.
Old 10-15-2006, 02:06 AM   #10
Supra2NR
Supra2NR's Avatar
are you guys talking about when racing?
its not that they manually shift thier car
most pple with autos jus launch it
by putting it in the lowest gear possible
P R N D 3 2 1
for example they will put in that in 1
get it redlined and then moved it up again to drive
this is a way to get a really good launch with an auto
but for the tiptronics out there,
manumatic, paddle shifter, whatever
i said what i said and i will say it again
hope thier right leg grows bigger than the left lol
Shifting Issues (Automatic) btwilson86 MKIII Supra 4 11-03-2007 07:05 AM
Hard Shifting in Automatic. redmaro MKIII Supra 2 05-18-2007 04:08 AM
Automatic transmission strength pgoughary MKIII Supra 0 12-29-2006 06:48 PM
Is Automatic Turbo worth it ? XKeyLocX MKIII Supra 9 01-27-2006 06:25 AM
Manual Shifting Trouble KingJames224 Non-Generation Specific Questions 3 10-22-2005 09:26 PM
