#4 |
7M POWAH! ;)
ok i wouldn't rebuild your engine just yet....
have you check your valve covers/rocker covers/cam covers to make sure the gaskets aren't leaking... they could be leaking oil down and when you remove the spark plug the oil is just flooding them as you pull it out.. it may not necessarily be your rings.... check your valve covers first (get some high temperature silicon and lightly around the gaskets put a little film of silicon... not too much because you don't want it going inside the head.. or just buy some new gaskets and clean the surfaces of the head so no grime is on there) clean all your plugs does your car smoke? if it does when does it morning white smoke is normal what colour? when you pull out your plugs and clean it all up when you start your car there will be huge plumes of smoke but they will clear let me know how you get on so far and i will continue ![]() good luck
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
Thread Tools | |
Display Modes | |
low boost psi, wtf | supradad86_5 | MKIII Supra | 4 | 02-09-2014 02:05 AM |
wont hold boost | Supraman | MKIII Supra | 12 | 04-19-2007 04:52 AM |
issue w/ boost spikes? i think? | NOTORIOUS VR | Non-Generation Specific Questions | 17 | 01-17-2007 08:35 PM |
No boost while in park or neutral | adamh88 | Non-Generation Specific Questions | 5 | 04-09-2006 11:54 AM |
installing manual boost controller 1989?? | hamburgler | MKIII Supra | 4 | 07-13-2005 12:55 PM |
