Old 10-17-2006, 06:42 PM   #1
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Default Fluid Reccomendations. Such an improvement!
Okay I put this tuff in my car...I will list what I was using before and what I changed it to and I can tell you right now there is such a difffrence it's rediculous.
Used Before:
Limited Slip Diffreiential Gear Oil: Unknown but I have a feeling its never been changed. Had a slight burn smell to it but no metal in drained fluid so thats good.
Automatic Transmission Fluid: Dexron II
Motor Oil: Mobil One Full Synthetic 10W-40
Okay that being said, Mobile One is considered to be one of the best synthetic to use. I am anal about changing my oil on time. Anyway here is what I did:
Changed to:
LSD Gear Oil: Royal Purple 85W (Toyota Suggs 90W, but 85W is what you should use)
ATF: Dexron II with 1.7QT's of Trick Shift Synthetic (from draining the pan)
Motor Oil: Royal Purple Full Synthetic 10W-40
I can tell you right now that after doing these things I noticed right away the diffrence. My tranny feels like a performance transmission, my LSD performs better than I think it ever has. And the motor oil, well I can tell you that my engine is quieter. My transmission even sounds better. Mind you when I drained the tranny fluid from the pan it was a nice red color with no metal shards or anything so my tranny was performing as it should. But now the shift points seem better and it downshifts Immediatly when putting the accelerator all the way down. So my suggestion is shell out the extra cash it pays off. My acceleration has improved a gripload to.
Please note:
DO NOT USE TRICK SHIFT REGULAR! OUR AUTO TRANNYS ARE ELECTRONICALLY CONTROLLED YOU MUST USE THE SYNTHETIC TRICK SHIFT!
Right now I am going to go buy some more trick shift and drain the pan again and add more Trick Shift Synthetic. B&M (the makers of Trick Shift) say it acts better as a standalone but can be used as an additive. I hope this helps some of you.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-17-2006, 08:50 PM   #2
redmaro
I am actually thinking about changing my tranny fluid to sysnthetic.
Ive seen B&M transsmision fluids. Is B&M tranny fluid good for daily driving?
Old 10-17-2006, 09:43 PM   #3
tone loc
tone loc's Avatar
i hear if you go from mineral to synthecic oil its not good for the engine. not sure. can someone clarify?
Old 10-17-2006, 10:17 PM   #4
ravenmaster
Thats in regards to newer engines not older. When your engine is new it needs the mineral oil to help break in the engine, but usually it is okay when it comes time for the first oil change to switch to synthetic. There are alot of rumors about the "dangers" of synthetic, don't believe them. but it is all I have used in my cars and I have never had a probelm.
Old 10-18-2006, 05:16 AM   #5
Isphius
Isphius's Avatar
Good, cause i gota change my trans and rear end fluid too. Sounds like ill go with that trick shift stuff.
Old 10-20-2006, 06:24 PM   #6
brandonsupra
brandonsupra is on a distinguished road
Quaker state 5w-30 fully synthetic motor oil
dextron II ATF
Lucas oil treatment for high horse power engines (this stuff is worth the 25$)
The only thing switching from mineral to synthetic will do is expose existing leaks. Which can be annoying but in the end is a very good thing. Don't want those leaks to get too out of hand.
brandonsupra is offline   Reply With Quote
Old 10-21-2006, 01:44 AM   #7
mad_dicer
mad_dicer is on a distinguished road
this is what i use.
oil filter K&N
oil valvloine 10w30 maxlife syn
rear diff fluid GL5 syn
manual tranny GL5 syn
power steering valvoline maxlife ATF fluid
coolant i use valvoline maxlife
mad_dicer is offline   Reply With Quote
Old 10-21-2006, 01:47 AM   #8
mad_dicer
oh yeah the GL5 syn is also valvoline fluids
Old 10-23-2006, 11:59 AM   #9
scruffboy
scruffboy's Avatar
Default I heard just the oppositie
MrNickleye, whose advice I take to be very good, said synthetics are good for newer cars with tighter tolerances, but with older cars stay with natural oils, and for high mileage cars he recomends 50W-20 for the motor. See how much different info is out there.
Scruffboy
Old 10-23-2006, 05:15 PM   #10
ravenmaster
While I res-pect MrNickelEye like no tomorrow this is something I disagree with him heavily on.
Transmission Fluid capacity suprabahamut Non-Generation Specific Questions 2 09-18-2008 04:30 AM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Brake Fluid Reservoir igosaur MKIII Supra 2 06-28-2007 10:55 AM
Draining Transmission Fluid? RNEMESiS42 MKIII Supra 20 05-17-2007 10:17 AM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
