-   -   Loose shifter, missing coolant! (http://www.toyota-supra.info/forums/mkiii-supra/6445-loose-shifter-missing-coolant.html)
XtreeX 10-18-2006 07:46 AM
Sup guys. I did some searching and found a few threads on the topic but not a definitive answer or anything. Anyways, my first question is if the Supra 5-speeds shifters are all generally loose? I had a 97' 5-speed maxima and even my moms 5-Speed Jetta both shift alot 'easier.' An example of this is when im in a gear i can slightly move the stick from left to right, where as on any other stick I can't. Can this be tightened? I'm not that mechanically saavy yet and is this something i can do myself?
The second problem is that Im loosing coolant, and i dont know where its going. Its not being pushed out the overflow and I have no leaking what so ever. There is also no white puff of smoke when i start the car, oily dipstick or milky oil. I also do not overheat. The only mod that I've done to this car is shimming the wastegate a bit. But the car was losing coolant before that. It's at the local import repair shop and has been for a few days, he can't seem to find the problem. I think he's just been trying to replace stuff and see if it helps it. Any ideas?
thechori 10-18-2006 10:51 PM
yea i've got both of those. i'm not really worried about the shifter, but the coolant is beginning to get my attention
XtreeX 10-19-2006 07:30 AM
After being at the mechanic for 3 days they ruled it is just a BHG. really kinda sucks LOL. Pay $1700 for the car and going to have to double it on a repair. But all for the love of the supra!
The shifter kinda bugs me, its really hard to get into second sometimes and its just very very loose. Doesnt feel tight.
Murd 10-19-2006 12:24 PM
Replace the bushings on the shifter, should fix that.
XtreeX 10-19-2006 06:14 PM
Is there a writeup on how to do that? Is it something i can accomplish in my garage with just basic tools? tia
Murd 10-20-2006 02:15 AM
here's the closest I could come to finding a write up on short notice...
http://www.supras.com/06/techcenter/display.php?QID=30
It's for a short shift mod, but should help you with what you want to do.
XtreeX 10-20-2006 05:46 PM
You know i saw that and I was actually debating on whether or not to do it or not.... Im deffinetly capable of doing it, and i dont like how tall the stock shifter is but im worried that the short shift mod will be way too short too. So if anyone has done this mod already and has some pictures i would really, really appreciate it. Thanks Murd!
brandonsupra 10-20-2006 06:20 PM
While we're on the topic of losing rad fluid I'll step in here for a second. Mine is losing a bit of fluid as well, and sometimes I can smell anti-freeze. I don't have any milk in the oil, no bubbling, no strange smokes out the exhaust. Could this be a leak in the heater core? I had a heater core leak in another car and the floor/mats were always soaked and smelling like anti freeze but this isn't happening. My oil pressure regulates fine, and I see no signs of BHG. The only sign of a BHG I observe is the "water-fall" sound at start up but I read that can just mean the rad needs a good burping? Any ideaS?
BP907MGTE 10-20-2006 08:50 PM
i found out why the car looses so much water per day, well on my car it was a bad water pump, so i gotta get that replaced, its like 45$ for a new pump, so u may wanna check that. if u see water dripping when ur in neutral, look under the car near the main pully, if u see water dripping, its the bad pump. hope i can help
marc 10-22-2006 04:57 AM
actually, i have a short throw shifter on mien and i lvoe it, it is short tho. not too short, but hsort. it really alows u to throw it into the gears, and get reallllllly fast shifts off. ill show ua pic tommroow when i can take it in the light.
boogum7 10-22-2006 06:10 AM
shifter
2 Attachment(s)
here is pictures of my short shifter mod.
i used that link and it took about 30 minutes to an hour to get it out and put it back in.
XtreeX 10-22-2006 09:36 AM
Yea im just going to have the timing belt, water pump, bhg and tranny fluid all switched. Hopefully no more loss of coolant at all! And I like that it doenst look to bad.
f00g00 10-22-2006 09:45 AM
Check the hoses ans piping behind the head. The piping is universal and has outlets on both sides so it can go into a lhd or rhd car without having to change to another pipe setup. One side has the heater hose and the other has a plug. A small pinhole leak could drip on the starter area and trickle down the transmission and you might not ever see it till it finally blows. If you look over the whole area and see no discoloration from fluids then its probably OK. You can also squeeze the hose when its cold and see if you can get anything to leak there too.
ddmcse 10-23-2006 07:13 PM
i replaced a small plastic ring that goes on the bottom of the shifter
" replaced "
isn't the right word because when i got the shifter out i found that the plastic ring that is supposed to be there wasn't there . i had the play for years and never got around to it
it's not that difficult just a few bolts
