Old 10-20-2006, 07:47 PM   #1
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Default Need your gus help- a few questions
Okay these questions are in regards to a 1987 Toyota Supra N/A. I will be posting pics to assist in what I am talking about.
My questions are for the fuse box in the engine com-partment what is the color of the wires that are suposed to go to the ABS Fuse? It apers my cnnections for it are missing so I need to recify that.
Secondly I installed a new Engine o2 sensor from a 1990 toyota supra n/a and reattached the whole EGR system and installed a new AFM from a 1995 Toyota Camry (same size as that of the stock one) and when I started it u it seemed fine, but when I pushed on the accelerator it would rev slightly then go back to idle and keep doing it. Then I drove it around and slowly sped u and it did it for awhile but then the problem went away. I cannot figure out what could have -possibly caused it but something just doesn't seem right and the -performance seems to be lacking. Not severely but a little. My question s I didn't do anything to the new AFM at all was I supposed to before putting it in? Or any opinions on what might have caused this?
Last questions there is a wire (refer to pics below) that is yellow with a black stripe that comes from the ECU? wire cluster that I cannot figure out where it connects to. Anyone know?
Anyway some pics. And yes I know my engine compartment is dirty as hell I am working on that.
engine:
Wire that I am referring to;
And some fun p-ics:
In refereence I am re-placing teh mirrors with ones from a 1990 Su-pra as well as the Tailights thats why its missing.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-20-2006, 08:03 PM   #2
tone loc
tone loc's Avatar
you might not getting enough air in the engine. make sure there is no vaccum leaks (use carb or brake cleaner) it might be the afm sending the wrong signal. was the camry afm the same size or are u sure that the supra and camry afms are exactly the same?
Old 10-20-2006, 09:17 PM   #3
ravenmaster
On visual inspection they are the same size, shoot even the same wieght. The -problem went away as I said I just wish I knew what caused that anyway no biggie. anyone know the answer to the other two?
Old 10-20-2006, 11:33 PM   #4
ravenmaster
help...please? LOL sorry guys but I really need to know the answer it appears to me for the ABS it should be a blue one with a red stripe and a black one...only problem is there is no black one that I can see but there is a disconnected blue with red stripe one....anyone know?
Old 10-21-2006, 01:01 AM   #5
Murd
I don't think your car has the ABS unit, it should be right where your charcoal canister is, big sqaure hung of aluminum. Probably why you don't have wires going to the fuse.
Old 10-21-2006, 04:28 AM   #6
tone loc
tone loc's Avatar
oh well then something probably just had to be broken in or something but if the problem happens again deffiently check the afm
judging by the engine pic you do not have abs (it would be like a golden box10"x10" with brake lines coming off it right next to the charcoal canister)
you know about the tsrm right? big help http://www.cygnusx1.net/supra/
Old 10-21-2006, 06:39 PM   #7
ravenmaster
The more work I do on this car the more pissed off I get. I keep finding stuff missing. I rechecked the -paperwork given to me by toyota and sure enough right there "ABS Included".
So far this is what I have found out has been removed:
ABS
EGR
TEMS
"sigh" what next?
Old 10-21-2006, 08:36 PM   #8
tone loc
tone loc's Avatar
that is shity were did you buy the car from?
Old 10-21-2006, 08:38 PM   #9
ravenmaster
_PAsadena off a guy who is supposed to be in the academy to be a Sherriff. What a jerk. And when I called him to tell him what was going on he ignored me completely/
Old 10-21-2006, 08:41 PM   #10
tone loc
tone loc's Avatar
what a fag. did the car orginaly have abs or he just lied to you (same question for the tems)?
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
