i love the supra, i have since i first became a motor head. i am looking to buy a mkiv but know i can get a mkiii for much cheaper. what kind of speed could i get out of an mkiii if i put 1500 into the engine. anybody got any ideas
Most of the good horsepower gains are in the heads, so work on that. Little bigger valve, play with the cam timing some and make sure the porting job is down right. Header, pipe and muffler should be low restrictive and a good air filter. Advance the timing as far as you can with the fuel you use and it will be better........enough........well who knows untill you find a challenge.
Russ |
thank you, russ. but surely not a all that can be done for $1500
1500 is just scratching the surface. get the car you desire most
mkiii is a cheaper to mod by the way
#6 |
Two major diffrences in the two cars ( iwill be going with the turbo here):
1.The Engine: MKIII: 7MGTE 230HP stock MKIV: 2JZTE 340?HP stock 2. The body weight: MKIII Is a little to alot heavier...all metal body fenders etc...come to think of it the only parts that isn't metal is the bum-pers. LOL the MKIV had a mix between metal and fiberglass so it weighs lesss. I -prefer the MKIII's myself but its a mater of what you most like
1988 Toyota Supra Turbo Targa Tokico Illumina II's (TEMS) | Eibach Pro Springs | SpeedTech AntiSway Bars | Cusco Strut Tower Bars | Lexus AFM/550cc Injector Mod | SOGI short shift mod | Aluminum Driveshaft | Upgraded Fuel Pump | 12 PSI Boost | MHG | 11/30/08 Dyno 362RWHP 326ft/lb ![]() |
1JZGTE Horsepower potential? | Ungoliant | MKIII Supra | 18 | 08-06-2014 09:28 AM |
Advice on Potential Buy | RyDeFly | MKIII Supra | 7 | 12-07-2005 05:06 AM |
86 Supra Turbo Potential? | AJM187 | MKIII Supra | 4 | 10-04-2005 03:30 PM |
