Old 10-27-2006, 02:54 PM   #1
damdog05
damdog05's Avatar
Default Help Me!!
i was on my way to work taoday and my car just died. i turned the key and it tries to turn over but i get nothing. after i did that for a while i could smell a whole lot of gas. recently i have been getting a code 12, 14, 22, 43, and 51. i know my tps is bad, idk if thats the problem here or not. please help. this is my daily driver and i have no other way to get around. its a 1986.5 n/a manual
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 10-27-2006, 03:00 PM   #2
damdog05
damdog05's Avatar
remembered another thing...when i shifted from 2nd to 3rd, my car jumped a little like the transmission stuck or something. it did the same thing from 3rd to 4th. then it died. a tried starting it with the key while it was rolling, nothing. and i tried popping the clutch out in 1st and it still didnt start.
My cars:
Old 10-27-2006, 03:39 PM   #3
bigdoggbmx
bigdoggbmx's Avatar
bigdoggbmx is on a distinguished road
hay yo check your coil this will make all these simtoms and all the plug wires
of the car to stall and die
bigdoggbmx is offline   Reply With Quote
Old 10-31-2006, 06:39 AM   #4
try resetting the ecu and do a fresh diagnostic
have you unplugged the coil, ignitor, afm etc recently?
check your grounds also... lower intake manifold... make sure they've got good contacts
Old 11-01-2006, 09:36 PM   #5
damdog05
damdog05's Avatar
i had lots of oil in my #6 spark plug. so i replaced the valve cover gaskets, plugs, and wires. it runs great now. fix the problem i had with morning start up too. i know i need a new tps and i have it on order. every time i push in the clutch my rpms drop to zero and it dies. will the new tps fix this problem?
My cars:
Old 12-26-2006, 02:09 AM   #6
gomezmk
How do you reset the ecu?
Old 12-26-2006, 02:14 AM   #7
skunk
skunk's Avatar
Default .
the only way I know of is to pull the neg battery terminal for a couple minutes. Then reconnect
Old 12-26-2006, 05:18 AM   #8
damdog05
damdog05's Avatar
you can pull the EFI fuse in the engine compartment fuse box. this does the same thing without reseting your clock and any stereo equipment you might have. just pull the fuse for like 20-30 seconds and put it back in.
My cars:
Old 12-28-2006, 04:31 AM   #9
Monkey
Monkey is on a distinguished road
Pull the ecu fuse or disconnect the battery.
Monkey is offline   Reply With Quote
Old 01-02-2007, 02:47 AM   #10
Zipakna
Zipakna is on a distinguished road
timing belt snapped
Zipakna is offline   Reply With Quote
