Old 10-29-2006, 02:02 AM   #11
Murd
Most of your HP gains on a N/A are going to come from lightweight parts. Flywheel, driveline, wheels. It doesn't actually "add" horsepower to the engine, but it does get more of the HP to the tires. Flywheel weighs about 15 lbs I believe, you can get 11 lb ones. Driveline I think will lose you another 5 lbs. Stock wheels weigh in at 23 lbs, so depending on wheels, you can lose alot of weight there too... The ones I'm looking at are 17 lbs, so 6 lbs per rear tire. Front tire weight loss is negligible for a horsepower gain, but can gain you cornering performance and braking performance.
Old 10-29-2006, 02:18 AM   #12
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Originally Posted by boogum7
downpipes are for turbo models only.
....uhhh wtf are you talking about? i have an N/A with a 3" downpipe...
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 10-29-2006, 07:55 PM   #13
boogum7
boogum7 is on a distinguished road
Default downpipe
are you talking about headers?
because a downpipe is the exhaust that comes off the turbo elbow or can bolt right up to the turbo.
headers come right off the manifold of the n/a.
stock
boogum7 is offline   Reply With Quote
Old 10-29-2006, 08:19 PM   #14
ravenmaster
Man I really have to work on my english better. Sorry my fault I was confused about the names. I stand corrected. LOL at least now I can change my sig to correct.
Old 10-29-2006, 11:31 PM   #15
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
Ok then what is the section of pipe called that goes from your headers to like the middle of the car?
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 10-30-2006, 06:56 AM   #16
boogum7
Default exhaust
this would be your catalytic converter then your exhaust pipe?
i don't know what else it could be.
stock
Old 10-30-2006, 07:00 AM   #17
h8z2luze
h8z2luze's Avatar
hmm, well I was all excited lol.
Old 10-30-2006, 07:19 AM   #18
tellfromchico,ca
tellfromchico,ca's Avatar
tellfromchico,ca is on a distinguished road
Red face
did you mean header
Originally Posted by h8z2luze
My car isn't a turbo. I have a cat-back 3" Blitz Nur spec system already so I was wondering how much would a downpipe help to my application. Also what about headers? i noticed that the stock manifold has pretty good flow already.
tellfromchico,ca is offline   Reply With Quote
Old 10-31-2006, 02:15 AM   #19
Isphius
Isphius's Avatar
Yes, A header replaces the stock exhaust manifold, And connects to the cat. you will probably see a nice high end increase with a header/cat/full exhaust. As for the lightweight stuff, yes this will also help a lot. the key to making power out of an NA is getting the air in and out faster and more compression, whereas with a turbo its getting enough fuel and boost.
Old 10-31-2006, 03:25 AM   #20
RTZ
RTZ's Avatar
RTZ is on a distinguished road
ive recently added a 3" exhaust elbow (bought from supra_girl) direct from turbo to custom 3" exhaust - made a BIG BIG difference, espeically in the low end.
The factory elbow is probably only 1.5 - 2" in diameter, very restrictive!
With the full 3" elbow the turbo spools up much quicker after shifts, i would def recommend to anyone with 7MGTE if youve got full 3" exhaust.
Air filter is a standard pod filter, which has worked well, you can hear the turbo working now!
It sounds mean in cold conditions and goes much harder, again would def recommend.
I have just installed heat sheild around the filter, as it was sucking in all hot air from engine until now, which wasnt helping...
Next will be piping from front of filter to inside of bumper to get purely cold air goin through.
RTZ is offline   Reply With Quote
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
