Old 10-31-2006, 08:47 PM   #1
west_side_supra
west_side_supra's Avatar
Default windows locks and seats
ok my clutch seized on me for some reason, i got me a new clutch put in and since then my power windows, locks, and drivers side seat are not working, why? is there a fuse for these items? where?
Old 10-31-2006, 10:27 PM   #2
tone loc
tone loc's Avatar
im sure there so check your fuses
Old 10-31-2006, 10:39 PM   #3
west_side_supra
I have looked at the fuses on the drivers side and passenger side kicker panels and they are all fine, i have also looked at the relays and fuses in the engine compartment they are all fine, WHAT IS GOING ON HERE!!! AHHH jeeze is all started off with a simple welding of a new muffler, then the clutch seized, now this. i bet you next my head gasket will blow
Old 11-01-2006, 04:59 AM   #4
west_side_supra
or could someone send me a wiring diagram of the 87 supra turbo door?
trevorpollett@hotmail.com
Old 11-02-2006, 09:06 PM   #5
west_side_supra
mmm help? anyone?
Old 11-02-2006, 09:55 PM   #6
SupraDupra
SupraDupra's Avatar
Possibly knocked out a breaker on the fuse panel?
From my Supra manual...
"To reset a manual circuit breaker, first disconnect the cable from the negative battery terminal.Remove the circuit breaker, insert a pin into the reset hole and push in..."
Unfortunately my scanner is not working at the moment ,but it's a semi-round block with a hole in it.Best of luck to you.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 11-03-2006, 10:40 PM   #7
west_side_supra
well i tested it out, and the circut breaker is not wanting to stay engaged, i dissconnected the neg. and pulled it out, then poked it and it keeps clicking back out. i grabed a diffrent circut breaker and put it in the same spot and it does the same thing, so does this mean that there is a bad ground somewhere? if so where would it be located?
thanks again guys
Old 11-05-2006, 09:04 AM   #8
west_side_supra
OMG this is just getting worse, now its acting as if the clutch pedal sensor isnt working, i will apply the clutch all the way and it wont start, i can still push start it, the pedal is hitting the button all the way, i have even pushed the button all the way in with my finge and it still wont start. what have i done to the supra gods, i swear they are just onto smiteing me these past 2 weeks. jeeze im also starting to have troubles with the po po's again. give me your ideas on my problems peoples thanks
Old 11-05-2006, 05:16 PM   #9
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
test your alternator. mine went bad and i could only start my car by rolling it. but it worked enough to keep my car running. all i had to do was get a new one and problem solved. just take it off, go to an autozone or something, and have them test it. its a very simple process
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 11-07-2006, 10:06 PM   #10
west_side_supra
the alternator is fine, it is recarging, and it stays between 13/14 volts.
