Old 10-31-2006, 11:18 PM   #1
ex3cutiv3
ex3cutiv3's Avatar
ex3cutiv3 is on a distinguished road
Default TUBRO (yeah i spellit weird) HELP! PLZZZL
Hey I have an 89 turbo and it runs but the turbo doesnt seem to. On the road tho sometimes the stock gauge would jump to 8 psi. It sits on the 0 when driving and -4 when its idling. ALso it puffs out random white smoke and it runs absolutely perfect otherwise!!?? ANy suggestions? Thanks
- Ex3cutiv3
ex3cutiv3 is offline   Reply With Quote
Old 11-01-2006, 12:43 AM   #2
Murd
Correct me if I'm wrong, but that sounds like the way a stock turbo is supposed to act. At idle it has negative pressure, no exhaust pushing the turbo. At normal driving to slow acceleration it could be 0-4psi and under full acceleration hit 6-8psi?
Old 11-01-2006, 12:45 AM   #3
ex3cutiv3
ex3cutiv3's Avatar
i understand that but under full accel it says 0 and at normal drivin it will pop up to 8 then downto 0 instantly.
Old 11-01-2006, 12:46 AM   #4
Murd
Does the car feel like its under boost when you accel or does it feel boggy and slow? could just be a bad gauge.
Old 11-01-2006, 12:48 AM   #5
ex3cutiv3
ex3cutiv3's Avatar
its wayy slower than the stock n/a! lol its bad
Old 11-01-2006, 12:50 AM   #6
Murd
Do a diag
http://www.toyota-supra.info/forums/...read.php?t=323
From what I've read from other posts here my might have a vacuum leak somewhere. If I had a turbo I'd be of more help but I'm just a N/A
Old 11-01-2006, 12:55 AM   #7
j3pz
does it feel like its boosting normal when you hit the accel or when you hit the accell you get no boost?
might have a leak under heavy boost
Old 11-01-2006, 12:57 AM   #8
ex3cutiv3
ex3cutiv3's Avatar
I had already done a diag and it came up a 52 (knock sensor) and that was all.
Also the car is not boosting wat so ever.
Old 11-01-2006, 05:29 AM   #9
what's to bettin code 34 was there
fix your intake, vacuum or boost leak
how much fuel have you been going through?
how does it idle?
Old 11-01-2006, 03:52 PM   #10
Isphius
Isphius's Avatar
The white smoke could also indicate a BHG or shot turbo. lol. And try to borrow a friends boost gauge, one with a vaccum line, or just go buy a cheap one, The stock ones are known to suck.
