Old 11-03-2006, 12:41 AM   #1
nickvash0104
nickvash0104 is on a distinguished road
Default Knocking Under Acceleration
Hello everyone,
On my 87 NA Automatic, I'm getting a knock under acceleration. The noise is coming from around the transmission / driveshaft and I'm suspecting a bad u-joint. The engine was replaced in April and I've had no problems since then. Some points to consider:
*It occurs intermittently.
*Usually happens in the 2200-2700 RPM range in drive.
*Does not occur in neutral, reverse, or park.
*All fluids topped off.
*When letting off the gas, it stops instantly and usually does not resume when giving it gas again.
What just confuses me is that it happens intermittently, seemingly without a pattern.
Suggestions?
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
Old 11-03-2006, 07:18 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Do you here a knocking noise from cold start up and then it disappears until you fev it to about 2K.?
Old 11-04-2006, 12:22 AM   #3
nickvash0104
Nope.
Doesn't matter if the car is warm or cold.
Doesn't happen at idle.
Only under throttle (any amount of throttle) in the 2.3-3k RPM range.
Very rarely 1.7-2k range.
Black '87 N/A Auto
Old 11-10-2006, 10:20 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Initially I thought big end bearings but you would get the knocking noise about 2K and at start up but it sounds as if it could be the crankshaft pulley; they are known to come loose.
Old 11-13-2006, 02:39 AM   #5
nickvash0104
Question though, how could it be the crank pulley if the sound is coming directly below / behind me? Correct me if I'm wrong, but isn't the crank pully in the front of the engine?
Black '87 N/A Auto
Old 11-13-2006, 09:31 AM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Yep! crank pulley is at the very font of the engine, I only mentioned it because knocking noises are associated with big ends or something like the crank pulley coming loose.Also location of noises can be deceptive, as it was easy to check I thought it was worth mentioning the pulley, and it seemed to be related to eng revs. At least it keeps your thread on the front page.
Old 03-26-2007, 01:32 AM   #7
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
It's possible your u-joint in the drive shaft has worn out. Mine did the same about 2 years ago with roughly 200,000 miles on it. It would knock during initial acceleration at 2k-3k rpm or if I was cruising and then sped up causing the drive shaft to break loose from the u-joints worn out bearings. Try getting under your car and jiggle the shaft near that joint. If it feels really loose then replacing one shouldn't be so difficult. 4 bolts to the diff and 2 holding the u-joint up and the shaft slides out from the tranny. You might want an extra pair of hands to hold that thing up while you bolt it off and on. I have an 87 Auto N/A btw.
Drag0na5h is offline   Reply With Quote
Old 03-26-2007, 08:01 PM   #8
f00g00
sounds like the center bearing that connects the two small driveshafts together. If you change it yourself be careful to mark the way they came off so you don't get the driveshafts out of alignment or you will get some serious vibration problems at around 60 mph. The driveshafts and center bearing are balanced at the factory.
Hard Engine Knocking 86SupraMan MKIII Supra 10 09-14-2007 05:39 AM
funny knocking sound on 7mge Jeff_5_7 MKIII Supra 11 09-09-2007 01:22 AM
Help with knocking on front end supra96 dini_the_owl MKIV Supra 8 09-03-2006 10:24 PM
knocking block, want to build solid bottom, what should i use alcbarrios MKIII Supra 1 04-14-2006 04:16 AM
acceleration problem 91 2 litre supra sexy91tt Non-Generation Specific Questions 2 01-28-2006 09:43 AM
