-   -   Radiator repair??? (http://www.toyota-supra.info/forums/mkiii-supra/665-radiator-repair.html)
minnesotasupra 04-12-2005 11:26 AM
Does anyone know if it's possible to replace just the top tank cover on a 7MGE radiator...? I've got a crack in the plastic, just inside the 0-ring.
Thanks for any suggestions!
monkihead 04-12-2005 04:08 PM
i'd just replace it. plastic sucks. if you measure the dimensions, check with summit racing, jc whitney or behrents mail order parts. you might be able to get an upgraded radiator for the cost of a stock replacement. if you want a stock replacement with a lifetime warranty, find a local shop that gets them from 1-800-radiator. very good ones....
hangsupra 04-13-2005 01:28 AM
well...if the one you have on now is the stock one...than if you like upgrade than yeah go ahead order the aftermarket one.....it cost little more $$ but it worth it....
