Old 11-06-2006, 02:52 AM   #1
ZauggIt1
ZauggIt1's Avatar
ZauggIt1 is on a distinguished road
Default Oil Pump??
What do you guys recomend for priming the oil pump, when we have the plugs out and crank it we cant get any pressure. do you think it will be ok if we just start it up and run it until we get pressure?? its a 87 turbo. Freshly built motor too. Please help, we get the new turbo tuesday!! thanks for all help!!
Drive it like you stole it!!!
ZauggIt1 is offline   Reply With Quote
Old 11-06-2006, 11:36 PM   #2
ZauggIt1
ZauggIt1's Avatar
so no ideas out there on this situation??
Old 11-09-2006, 06:02 AM   #3
mrnickleye
mrnickleye's Avatar
The 7m only gets about 7 lbs pressure at idle anyway.
I'm sure you used a good engine assembly lube when you put the motor together, so you should be fine to start.
Power Steering Pump Whining Chambers MKIII Supra 10 01-28-2010 07:19 PM
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
