Old 11-07-2006, 02:53 PM   #1
Nova504
Nova504 is on a distinguished road
Default Braking Problem?
I have an 87 supra turbo, and at speeds of 60+. When I go to apply the brakes, my pedal is super hard and cause to car to fishtail.Under 60 mph, the car stops fine. It is scary and dangerous, to drive it on the highway( I dont even drive it on the highway anymore). Can someone please help me, I need to fix this problem ASAP.. I would greatly appreciate the assistance with this matter.
Nova504 is offline   Reply With Quote
Old 11-07-2006, 08:39 PM   #2
thechori
thechori is on a distinguished road
wow that's crazy, good luck with finding a solution
thechori is offline   Reply With Quote
Old 11-08-2006, 01:20 AM   #3
ddmcse
ddmcse's Avatar
Cool
Anti Lock Brakes ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 11-08-2006, 03:33 AM   #4
jfunez
jfunez's Avatar
it sounds as if your booster doesnt hold vacuum or the car is not generating enough vacuum at high speeds to fill the booster....!!!
does the pedal get hard at those speeds?
Old 11-08-2006, 03:36 AM   #5
jfunez
jfunez's Avatar
Originally Posted by Nova504
. When I go to apply the brakes, my pedal is super hard and cause to car to fishtail..
aparently it does...lol..
anyways,check for vaccuum leaks or that the vacuum hose that leads to the booster is properly attached . that could be a sign of bad piston rings or valves..
but check the obvious first.
Old 11-08-2006, 11:20 AM   #6
mad_dicer
mad_dicer is on a distinguished road
does your car have ABS. and when ya hit the brakes does it nose dive (front end drop down alot)
mad_dicer is offline   Reply With Quote
Old 11-09-2006, 06:00 AM   #7
johnkarl
johnkarl is on a distinguished road
Default scary breaks
Check your two front calipers to see if they are seized up , that is the only thing that i can think of as it sounds like 95% of your breaking power is being sent to your back wheels , hope this helps- Karl
johnkarl is offline   Reply With Quote
Old 11-11-2006, 01:27 AM   #8
Nova504
Thanks Guys, I will check my calipers to see if they are seized up, and I do have abs. Lord I hope I dont have internal damage.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Nissan Sentra Tranny problem. redmaro Off Topic Forum 2 11-28-2006 01:58 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
