Old 11-16-2006, 04:14 AM   #1
marc
Default hey guys, havnt posted in a while, but a new problem
1. my master cylinder for my brakes is gone, no fun w that.
2nd, my car will sometimes make a funny noise when i drive. it gets faster and louder as i rev higher and drive. its liek week week week week, sounds almost liek a blet. comming form the front of the engine, and is usually followed by engine over heating a little until i empty the over fill bottle back int othe rad. than the heat goes down, but noise continues. this does not happen all the time. it is just very annoying/loud/obnoxious when it does happen. any thoughts on this matter?
marc
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 11-16-2006, 06:07 AM   #2
tellfromchico,ca
tellfromchico,ca's Avatar
tellfromchico,ca is on a distinguished road
Red face
make sure and check out the water pump theres a drain hole on top in case the seals are worn out, that way it is visible for inspection. if there is a water leakage than change out the pump because it might seize on you. that might also solve your weekweekweek sound
ps make sure to tighten the alternator tensioner
tellfromchico,ca is offline   Reply With Quote
Old 11-16-2006, 08:55 PM   #3
Isphius
Isphius's Avatar
The overheating could be from a lot of things, But what comes to mind is your water pump being shot (said above), idler wheel for your belts and stuff, or your alternator or ac pump. My ac pump in my MC made a squeaky noise like that, But i just removed it.
Old 11-16-2006, 09:53 PM   #4
jfunez
jfunez's Avatar
posible water pump, but in my case its the idler pulley,,,get a sthetoscope and check it...be carefull with touching the fan..lol
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Buying supra need advice guys sisqojazz Non-Generation Specific Questions 1 03-21-2007 10:47 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
