Old 11-10-2006, 05:44 PM   #1
john buck
john buck is on a distinguished road
Default boost on stock motor
i was just wondering how much boost you can run on a bone stock 7m-gte. and also about how much hp can you make before the internals need to be upgraded. i did a search and turned up nothing. any help would be appreciated. thanks
john buck is offline   Reply With Quote
Old 11-10-2006, 06:33 PM   #2
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Really anything -past 9 is pointless on stock.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 11-10-2006, 09:18 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Shim the wastegate and remove both cats and you’ll get 14psi just before fuel cut-out, goes like a rocket.
Old 11-10-2006, 09:19 PM   #4
ravenmaster
Both Cats...I thought thats only if you had the Cali model.
Old 11-10-2006, 09:36 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
The UK 7M-GTE has two cats, one in the down pipe and one at the beginning of the main exhaust.(where the down pipe bolts onto the straight part of the exhaust).Providing the motor vehicle was registered before 1992 there is no restriction in removing them in the UK.
Old 11-11-2006, 04:24 AM   #6
twurbo.oggy
twurbo.oggy's Avatar
twurbo.oggy is on a distinguished road
yea, i got 2 cats in my poopra. but i gutted the second one.
twurbo.oggy is offline   Reply With Quote
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
How much boost could you run on stock 7mge internals? supraman121 MKIII Supra 2 02-22-2007 11:46 PM
How much Boost on Stock Internals? abhattan MKIII Supra 26 02-20-2007 06:30 PM
boost on stock with ct26? carlosemagana MKIII Supra 8 12-31-2006 07:48 AM
stock boost drgnframe24 MKIV Supra 5 08-26-2006 04:12 PM
