#1 |
i have the same problem to, ive just kinda ignored it. but ive found it never does it till the engine is warmed up, ill drive it normal and then ill pull up to a stop sign or a light and it will just drop from a 700rpm to 500rpm and it will idel very rough, i found just to push on the gas and let it sit at about 1000-1500 rpms and let the oil pressure sit for a while and let it off, and it will fix that problem for a while. but i have had it die but it will turn itself back on.
i think my code still is just the cold start sensors
![]() 7MGTE - 500hp ![]() exhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR |
Idling Problem! | Dejvid1785 | MKIII Supra | 22 | 10-05-2007 12:46 AM |
1986.5 Idling at high RPMS | Sasukevh | MKIII Supra | 2 | 06-14-2007 04:56 AM |
wierd thermometer activity | D_Train | MKIII Supra | 1 | 05-27-2007 01:15 AM |
wierd oil leak | mankatosupra | MKIII Supra | 2 | 07-08-2006 11:54 PM |
93 supra is idling high | kellyb | Non-Generation Specific Questions | 2 | 04-02-2005 02:06 PM |
