Old 11-10-2006, 05:44 PM   #1
john buck
john buck is on a distinguished road
Default boost on stock motor
i was just wondering how much boost you can run on a bone stock 7m-gte. and also about how much hp can you make before the internals need to be upgraded. i did a search and turned up nothing. any help would be appreciated. thanks
john buck is offline   Reply With Quote
Old 11-10-2006, 06:33 PM   #2
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Really anything -past 9 is pointless on stock.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 11-10-2006, 09:18 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Shim the wastegate and remove both cats and you’ll get 14psi just before fuel cut-out, goes like a rocket.
Old 11-10-2006, 09:19 PM   #4
ravenmaster
Both Cats...I thought thats only if you had the Cali model.
Old 11-10-2006, 09:36 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
The UK 7M-GTE has two cats, one in the down pipe and one at the beginning of the main exhaust.(where the down pipe bolts onto the straight part of the exhaust).Providing the motor vehicle was registered before 1992 there is no restriction in removing them in the UK.
Old 11-11-2006, 04:24 AM   #6
twurbo.oggy
twurbo.oggy's Avatar
twurbo.oggy is on a distinguished road
yea, i got 2 cats in my poopra. but i gutted the second one.
twurbo.oggy is offline   Reply With Quote
Old 11-12-2006, 03:22 AM   #7
j3pz
i got two cats and two mufflers... well two cats one muffler and a resonator( i think its called)
Old 11-12-2006, 05:53 AM   #8
jfunez
jfunez's Avatar
I still have to remove my first cat...the rest are gone..lol..
Old 11-12-2006, 06:17 AM   #9
Supra2NR
Supra2NR's Avatar
i tried asking this b4 too but never really got a straight answer
if u shim the wastegate
how much is still safe
considering the fact that the internals are stock
the fuel delivery system is still stock
most likely upgrades will be an intake and exhaust
how much can u push it?
why is it?
im not trying to b an a$$ about this
im jus curious and im trying to learn as much as i can
Old 11-12-2006, 07:21 AM   #10
ravenmaster
Becuase of a few things:
1. If you have a stock headgasket say goodbye to that. You want more boost than 9_PSI? Buy a BHG.
2. You will hit fuel cut past this. (9 _PSI is a rough number)
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
How much boost could you run on stock 7mge internals? supraman121 MKIII Supra 2 02-22-2007 11:46 PM
How much Boost on Stock Internals? abhattan MKIII Supra 26 02-20-2007 06:30 PM
boost on stock with ct26? carlosemagana MKIII Supra 8 12-31-2006 07:48 AM
stock boost drgnframe24 MKIV Supra 5 08-26-2006 04:12 PM
