Old 11-12-2006, 07:56 AM   #1
2JZEFINI-17
2JZEFINI-17 is on a distinguished road
Default Boost issue.. Kinda...
Ok so I wanted to see how my car boosts through the first 3 gears since I never really tried going WOT through the first 3 gears. Well first gear went to 10psi, 2nd gear went to 5 psi, and 3rd gear went to 5 psi. Shouldnt it be 10, 10, 10?? Should it hold steady boost readings or drop a little? I think my car is fairly quick but I am sure that if I can do 10,10,10 it will fly. Do you guys think this is a boost leak issue somewhere in the system? How much does it cost to shim the wastegate and can it be done easily? I heard that shimming the wastegate lets the turbo spool to 14 psi. I also heard that a divorced downpipe gives the supra 30whp is this true? Sounds like a rediculous gain for one upgrade.
I know this is alot to read but my last question is what kind of power am I looking at with these upgrades. Just give me a rough estimate. I was thinking like 320hp?
Aluminum Radiator
Front mount intercooler
intake
divorced downpipe
test pipe
shimmed wastegate
14 psi
2 1/2 in magnaflow catback
HKS SS Blowoff valve
By the way I have a new HG, Timing chain, and ARP headbolts.
Would that setup be safe if I used 14psi only when racing and kept it at 6psi when daily driving?
2JZEFINI-17 is offline   Reply With Quote
Old 11-12-2006, 02:54 PM   #2
Supra2NR
Supra2NR's Avatar
Aluminum Radiator
good mod
you already have a front mount IC if u have a turbo
why dont invest sum money first on sum hard pipes?
intake
everybody should have that, a lot of pple say its good for about 10-12 hps
test pipe
you live in illinois, if u ever get caught driving with this, the power:money ratio
is gonna tilt over to the money part cuz of all the fines/repairs your gonna be given
shimmed wastegate
not a bad idea, but if willing to buy all of those in ur list
why not jus get a boost controller, even a manual one
that what it basically does, only ghetto
14 psi
you're gonna be jus like a civic trying to race a mile
"u won bcuz i hit fuel cut" -civic
14 psi with no supporting fuel mods?
cmon man,, u got a turbo, 3 inch turbo back,
lesser restrictions, quicker exhaust gases get out of your system
more power ur car makes
sounds good and all, but im a greddy fan no offense lol
listen, the lucky number is nine (roughly)
do not try raising the boost so much without tuning, or without a dyno nontheless
you're gonna end up running too lean, and BOOM
well hope this helps u
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
Can anyone point me in the right direction on my boost? fienloco Non-Generation Specific Questions 9 09-07-2008 09:42 AM
boost issue mastergrader007 MKIII Supra 6 05-21-2008 11:10 PM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
What kinda boost can I pull off premium? WiseAssJester MKIII Supra 11 04-08-2006 03:49 AM
