Old 11-12-2006, 01:11 PM   #1
SupraDupra
SupraDupra's Avatar
Default Electrical short
I am having an issue that ,when I step on the brake pedal the lights on my climate controll go out.I first though that maybe someone patched into the power leads and there wasn't enough current to run everything but I took most of the dash off last night and nothing looks like it was spliced into and all wires are in good shape.I also get a check light on the dash when I step on the brake ,I assume it's the burned out tailight warning but all lights seem to be working.I removed the rear wiper and power antenna and didn't see any suspicious wiring in the rear either.I can't imagine where or why the climate controll and brake light harneses would ever intertwine but this has got the better of me.Any input?
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 11-12-2006, 02:41 PM   #2
Supra2NR
Supra2NR's Avatar
maybe extremely low on power? needs new battery?
happend to me once b4 too, everytime i accelerate the radio dies
Old 11-13-2006, 03:48 PM   #3
SupraDupra
SupraDupra's Avatar
Battery has a strong crank to it and the alternator is putting out a consistent 13 volts.Guess the next step is pulling off all the panels in the rear and checking all grounding points.I shall overcome!
1974 'Cuda - 318
2001 Cherokee
Old 11-17-2006, 12:37 AM   #4
jfunez
jfunez's Avatar
sounds like a bad ground or no ground...
Old 11-17-2006, 05:17 AM   #5
jeepkaiser65
jeepkaiser65 is on a distinguished road
x2, Id look for wires that run by the pedal assy.
Id rather die on my feet then live on my knees
jeepkaiser65 is offline   Reply With Quote
help please / short circuit ? smokinsupra Non-Generation Specific Questions 1 01-21-2008 02:43 PM
Wiper fuse short? kewlcoconut MKIII Supra 10 02-27-2007 04:43 AM
Oil Pressure...Mechanical or Electrical??? Luvs2slide MKIII Supra 5 08-23-2006 12:42 AM
Short Shifter?! 88Supraboy MKIII Supra 4 12-01-2005 09:13 PM
