Old 11-14-2006, 05:54 PM   #1
jeepkaiser65
jeepkaiser65 is on a distinguished road
Talking throttle body
I a trying to take my intake off my 7mgte, Ive taken all the bolts, elec. connections, and hosses off like the book says, but it still wont budge. I have tried using a mallet but it wont budge. Any ideas?
Id rather die on my feet then live on my knees
jeepkaiser65 is offline   Reply With Quote
Old 11-14-2006, 06:29 PM   #2
XtreeX
XtreeX is on a distinguished road
Towards the front of the intake there is this snorkel that goes under the passengerside headlight (not all the way but for the most part). Its tricky getting this out but if you pull back (towards the windshield) it'll move.
Also, make sure you get ALL the bolts.
And if you pull hard enough the accordian hose has enough give in it to allow the intake to come out.
XtreeX is offline   Reply With Quote
Old 11-14-2006, 09:07 PM   #3
burton51m
burton51m's Avatar
are you trying to take the whole thing out or just the black dome thing at the end?
i know mine was tricky
just keep on messin with it
Old 11-14-2006, 09:18 PM   #4
ravenmaster
ravenmaster's Avatar
Guys I think he means the throttle body.
1988 Toyota Supra Turbo Targa
Old 11-14-2006, 10:53 PM   #5
jeepkaiser65
Question
Yeah raven, sorry about that. I meen the throttle body. I have got the chamber seperated from the peice that connects to the head about 1/16", But something is holding it back. But now that yall brought it up Im looking at re-routing the air intake. Id like too see some pics of what ppl have done.
Old 11-14-2006, 11:10 PM   #6
ravenmaster
Check the underside of the throttle body ipe they have bolts that hard to see and frusterating to get off.
Old 11-15-2006, 03:44 AM   #7
jfunez
jfunez's Avatar
there is also a small coolant hose and the fuel feed line that have to be removed...
Old 11-15-2006, 04:10 AM   #8
tellfromchico,ca
tellfromchico,ca's Avatar
tellfromchico,ca is on a distinguished road
make sure u unbolt the egr valve its next to the firewall its kind of tricky a 12mm short socket with a 6inch extension should do the trick. theres two nuts top and bottom.
tellfromchico,ca is offline   Reply With Quote
Old 11-15-2006, 07:30 AM   #9
jeepkaiser65
Thanx yall, After I edited the post earlier I went out and felt around, sure enough there was a bolt on the bottom side closest to the firewall. When I pulled it out I found that a small hose and been broken bout it has like an inch disk kinda thing. I couldnt find anything about it in the book. Ill try to post a pic later. Will a gasket set from the local parts store be good? Or do yall recomend sumpin else? Is there an upgrades to the sytem that I can do right now. Im going to port them out, but I was wondering If there was a diffrent t-body, or intake? For ex. my buddy has an 87 300z. He removed his stock intake, t-body, and dist. and replaced with pathfinder items, which added alot of power. I was thinking about fabing an aluminum intake.
Old 11-15-2006, 04:29 PM   #10
jfunez
jfunez's Avatar
thats a filter ,the disk looking thing you are talking about, it just hangs there,nothing to hook up to.
as far as your buddys 300, it probably added low end torque,thats what the pathfinders are great with but as horsepower, he probably lost a few ponies on the conversion.
Cleaning Intake & Injectors mrnickleye Supra FAQ 6 03-23-2007 04:26 AM
