Old 11-21-2006, 09:36 PM   #1
marc
Default help please..
ok i took off the whole left side of the engine( accordian pipe, air filter, all that jazz). cause i had a feeling my turbo was burning oil because its losing more oil than wats leaking. there was a pool of oil in the turbo liek a small puddle, and the hose leading from behind the 3000 pipe to the turbo had oil in it. this hose is pumping oil into my turbo and i need to know why. does any1 know? what it is? the pic is below of wat pipe im talking about. its the small pipe that sits behind the 3000 pipe. any thing to help would be great. my dad seems to think it culd be a pcv valve problem? where is that located?
marc
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 11-21-2006, 09:38 PM   #2
marc
oh and 1 other thing. when i start my car up when its not warmed up, it idles at like 1500-1600. then wen it warms up it goes to about 700-800, normal idle. then if i shut it off and turn it back on in a little while it is still warm, it will idle real low, at liek 500 and starts to sputter and wants to die, but it never does.
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 11-22-2006, 03:47 AM   #3
twurbo.oggy
twurbo.oggy's Avatar
twurbo.oggy is on a distinguished road
yea, i kinda have that same problem. im pretty sure that its blow by that causes it. i have oil in my intercooler piping and right in front of the intake turbine. it is normal to an extent. i dont really know how you would fix it other than new rings.
twurbo.oggy is offline   Reply With Quote
Old 11-22-2006, 11:21 AM   #4
marc
new piston rings? i dont think those r the problem here.
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 11-23-2006, 03:45 AM   #5
marc
come on guys
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 11-23-2006, 06:22 AM   #6
twurbo.oggy
well, you said you were sputtering when the car got warm. so it could be that the oil from the crankcase is seeping past the rings into the combustion chamber and thats why your sputtering.
have you even checked your pcv valve yet?
Old 11-23-2006, 06:28 AM   #7
twurbo.oggy
and if you dont know where it is, you took a picture of it...
the pipe right behind the 3000 pipe is your pcv pipe
Old 11-23-2006, 07:32 PM   #8
marc
yes i know thats my pcv pipe, but where is the valve? my dad seems to think its the valve, but i dont know where the valve is, all the haynes book shows is the pipe also. so if any1 wouls like to explain to me where it is/how to check it if it is that/ how to fix it, i would be much obliged
marc
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 11-23-2006, 07:34 PM   #9
marc
and it doesnt sputter when it gets warm, it runs perfect, only when i start it after its already been running and then it sits for liek 10 mins it sumtimes sputters, but when i start it when the car is cold it revs high until it warms up but then it idles perfect.
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 11-24-2006, 04:31 AM   #10
redmaro
I think i have the same problem so some help would be useful.
MK3, Auto, Turbo.
