Old 11-22-2006, 04:34 PM   #1
89_supra_
89_supra_'s Avatar
89_supra_ is on a distinguished road
Exclamation 89 supra. lots of problems.. HELP!!
ok this just started on friday of last week.
i got out of the car, went inside to get something come back out to leave and it starts then quickly sputters and cuts out. tried it again same thing. but if i rev it really hard, it will keep going but i dont want to hurt the engine anymore than i probably alrady did.
someone told me it may be because of a dirty fuel filter,injector, etc.
if you can help me explain where are all these things your talking about are located so i can clean them.
89_supra_ is offline   Reply With Quote
Old 11-22-2006, 08:50 PM   #2
grygst76
grygst76 is on a distinguished road
codes??? Could be AFM, vacuum leak, e.t.c
89 Turbo, no mods yet
5 speed mbc to 10psi
grygst76 is offline   Reply With Quote
Old 11-22-2006, 09:59 PM   #3
SupraDupra
SupraDupra's Avatar
If you can get the codes from the computer that would help narrow things down...
http://www.toyota-supra.info/forums/...read.php?t=323
I could easily belive it to be a dirty injector.Are there any new whistling sounds? That would mean a vacuume leak.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 11-29-2006, 11:39 PM   #4
alcbarrios
alcbarrios is on a distinguished road
Default hmmm
sounds like a fuel problem or a vacuum leak, i would check the engine compartment for any loose hoses, if the car dont stay on though its going to be hard to do. check fuel pressure, if your under specs probably a bad fuel pump or restricted fuel filter, the fuel filter is located right above the differential in front of the fuel tank. what kind of maintenance does your car get, have you ever had your fuel injection system cleaned, try replacing the fuel filter and running some fuel injection cleaner in your gas. but try diagnostics first before you start spending money.
alcbarrios is offline   Reply With Quote
Old 11-30-2006, 03:02 AM   #5
supraman121
Fuel? i run the lowest octane and find that works the best in my car i went to middle grade and the car seemed to drive alot better when warm but it spitted and sputtered when it was cold?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 12-14-2006, 03:46 PM   #6
89_supra_
89_supra_'s Avatar
the codes i have is 26 25 and 51 and now theres a leaky hose in the back. i tihnk its from the radiator because i had no fluids in the radiator i put some antifreeze and water in it [50/50] and then steam came out from behind the engine and from the radiator hole. i burnt my hand from the steam . and yeah..
Old 12-14-2006, 04:00 PM   #7
89_supra_
89_supra_'s Avatar
can anyone help me pllease?
Old 12-14-2006, 04:59 PM   #8
OfnaRcR
I am not sure about the other ones but that code 51 is a bitch.
Old 12-14-2006, 05:08 PM   #9
89_supra_
89_supra_'s Avatar
uhh... kay, what is it and what do i do about it.
Old 12-15-2006, 02:28 AM   #10
burton51m
burton51m's Avatar
51 Switch Signal Diagnosis
  • No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
  • A/C switch circuit
  • A/C switch
  • A/C amplifier
  • Throttle position sensor circuit
  • ECU
86 supra problems dom747 Non-Generation Specific Questions 1 11-06-2006 03:52 PM
1986.5 supra problems jbandsons MKIII Supra 7 11-03-2006 12:12 AM
New Supra...lots of little problems. TxSpeedBoy Non-Generation Specific Questions 12 02-07-2006 03:32 PM
