Old 11-25-2006, 01:20 AM   #1
Supra2NR
Supra2NR's Avatar
Default Jus Got My Car
87 Turbo MK3
nice and everything but a few quirks on it
le me see the temp gauge isnt working
still smoking a lot from all the engine lube used during rebuild
and check engine light came on
but it pretty fast
its jus boostin at 5psi for now
any input in the afformentioned problems
Old 11-25-2006, 01:32 PM   #2
supra90turbo
supra90turbo's Avatar
try a new temp sender.
how much smoke? assembly lube goes on bearings, not combustion surfaces.
soo.... what codes did you pull?
Old 11-25-2006, 04:57 PM   #3
Supra2NR
Supra2NR's Avatar
im gonna do the diag. today
it gave me so much problems last night im not even kidding u
Old 11-25-2006, 05:30 PM   #4
SupraDupra
SupraDupra's Avatar
I never had an engine blowing smoke past breaking the cam in ,and I use engine lube pretty heavily.Did you use any special break in practices? I try to keep my engines under 3000 RPMs for the first 500 miles ,but all I know is rebuilding old V8s so far.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 11-25-2006, 06:14 PM   #5
Supra2NR
Supra2NR's Avatar
thats the thing it was under 3000 rpms when i was driving
Old 11-25-2006, 06:38 PM   #6
burton51m
burton51m's Avatar
can we get some pics?
Old 11-25-2006, 08:12 PM   #7
Supra2NR
Supra2NR's Avatar
ok, ill try to get sum pics when its smoking maybe you can get a better idea what im dealing with here
the guy is not pickin up his phone anymore, which is f-d up,
omfg, can never buy this car without the previous owner jacking u up
but i did a diagnostic, and a lot came up
!! !! - code 22 = water temp sensor signal
!! !!!! - code 24 = intake air temp sensor signal
!!! ! - code 31 = air flow meter signal
!!!!! ! - code 51 = switch condition signal
kinda a lot came up when i did this
well so much for my very first diagnostic
and i triple checkd the code reading
im pretty sure that is what came up
and p.s. thanx supra girl
to all the newbs that may read this
follow the girl's advice
"do a diagnostic first"
Old 11-25-2006, 08:26 PM   #8
Supra2NR
Supra2NR's Avatar
and one more thing i found out
can this cause my car to over heat
the hose underneath where the
cold start injector time switch, charcoal canister vsv, and turbo coolant line sits
the hose underneath has a nasty hole.
idk if u can call it, smoke or steam, but it was coming out of that
Smoke come right underneath the heatshield,
still unconfirmed where its actually coming from
and i found another thing,
the engine mount on the passenger side is not bolted on
that would explain why the car shakes more than usual
any help would be appreciated
help a fellow supra driver pls
Old 11-26-2006, 05:53 AM   #9
jfunez
jfunez's Avatar
wow, that was a crappy job the shop did.....I would take it back as soon as posible.....what in the world was done to it to begin with?
Old 11-26-2006, 10:44 AM   #10
Supra2NR
Supra2NR's Avatar
it blew a headgasket,
a metal head gasket went it
and a few issues with it
it wasnt from a shop it was jus fixed by the previous owner
he's a muscleman, used to jus engines , i guess
cuz the electronics are a little messed
up
im guessing its the oil line under the turbo thats burning
or its not getting the cooled right, cuz one of the coolant lines is busted
i'll try to see more tomoro
