Old 11-18-2006, 07:23 PM   #1
Lunch2000
Lunch2000 is on a distinguished road
Default Can't adjust timing...
After going round and round with my 89 turbo, I finally got a timing light this week and checked the ignition timing. I have been having problems with high fuel consumption and smelly exhaust and my suspicions were confirmed when I found that the timing had been advanced off the scale of timing marks. My guess is that it is advanced between somwhere between 15-20 degrees BDC. My problem is this, I can't move the cam position sensor far enough to get it to where it should be, I believe factory is 12 and I can only get it just on the scale before it hits the lockdown bolt. Do I need to replace the cam sensor or can I open it up and adjust it somehow to compensate. I would also add that the compression on the engine is higher than spec as well, about 180 as opposed to 140, so if anything I would guess I want it a little below 12. I checked the TSRM and my Hanyes manual but can't seem to find anything. Any advice from the Supra Ninja masters out there?
Lunch
'89 Supra Turbo 5-speed, 3" stainless exaust
Lunch2000 is offline   Reply With Quote
1991 n/a timing problems jerrods91supra Non-Generation Specific Questions 0 07-06-2008 09:44 PM
advanced timing? sd88supra MKIII Supra 7 04-27-2008 03:44 PM
Timing question. supramacist MKIII Supra 53 04-26-2008 11:41 AM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
timing issues stuck1 MKIII Supra 0 03-27-2006 02:16 PM
