Old 07-06-2008, 04:32 AM   #1
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
Default Car wont start hot
87 7mge manual.
Ive been trying to find out whats wrong with my car for the last 6 months.
When my car is cold it starts easy and runs fine, till I get somewhere. Ill kill it, when I come back to it after sitting 20 mins and the engines still hot it will turn over but wont start. If im lucky I can get it to but it spits and sputters for about 4 miles then clears out. The funny thing is when its running after a cold start the engine cant take full throttle pretty much falling on its face, but once the engine warms up its fast as hell. I cannot find the problem anywhere.
I have tested just about everything in the car and everthing so far checks out. I just did a diagnosis on it and im comming up with 51. If it was the neutral start switch the starter wouldnt even try to start the car. I replaced the o2 sensor, TPS, pickup coils in the dis., wires, plugs, coil, fuel pump, FPR, fuel filter, air filter, and battery cables. I also replaced the grounding straps from the trany to frame, and engine to frame. and I cleaned the grounds comming from the bat. ground to the frame.
I also took a ohm meter to these, MAF, control modual and I also check the wires going from the ecu to the, tps, maf, control modual, o2, and injectors.
Nothing is wrong with this damn thing so why doesnt it want to start when hot. All the hillbilly mechanics around here know nothing about supras. I just want my supra fixed. please help me
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Supra wont start Micahwc MKIII Supra 1 03-14-2008 05:57 AM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
