#1 |
I am building a tubular frame that will utilize the mk3 front suspension upper control arm and stock spindles. The lower control arm will be fabricated from 4140 tubing. I don't have the center of arm pivot to center of ball joint stud distance. I wonder if someone has one laying around to give me that size.That would be the shortest distance from center to center. The sc400/300 92-99 I believe is the same. I am looking for any info on stock steering setting like the Steering Axis Inclination, caster, camber, Pivot Radius, stock ride height, etc. I have been looking for somebody locally that I can slide under the vehicle with some measuring tools and get these specs. Any help would be greatly appreciated.
Thread Tools | |
Display Modes | |
Front Strut Bar - Quick Question | Grandavi | MKIII Supra | 6 | 09-25-2008 06:03 PM |
front coil spring... | hangsupra | MKIII Supra | 6 | 06-03-2007 09:25 PM |
have some questions about 86-92 supra suspension | jeremy_e87 | Non-Generation Specific Questions | 2 | 01-10-2007 11:53 PM |
squeeking front suspension | Bryan | MKIII Supra | 3 | 07-07-2005 12:38 AM |
